Just wanted to know how can i fit a sub into a vp ute? if anyone ahs done this could they let me know
And an amp and some speakers
search it.
Yep can be done. There is space in the tray floor where the fuel cell is located remove this panel and you will see a big area you can build a box and put a 10 or a shallow mount 12 inch sub in ther. This fires sraight into the cabin by the 3 vents you can see at the front.
Sounds awesome
what he said
not sure what the vp utes are like but in the vr's you can fit 2 10" subs in the spare fuel cell if you want a bit extra kick![]()
There are no stupid questions, just stupid people
same floor pan, the fuel tank sits on right side, where are you thinking of fitting the 2nd 10", its a tight fit for just 1 on the left side.
look on the proutes site, some nice setups on there
Japanese scientists have created a camera with such speed that they now can photograph a woman with her mouth shut!
if its anything like the later ones you might be able to run a bandpass box under (?) the back and have the port lead into the cabin. the amp and speakers would go in like a sedan, the amp might be ablke to go under the seat if its small enough or you could mount it behind the seats or even in the tray.
