Results 1 to 7 of 7
Thread: amp bridging
    dijm8's Avatar
    dijm8 is offline What You Looking At
    VZ SS LS3
    Jun 2006
    Default amp bridging
    ok i heard that if you bridge a amp u can produce maximun power.
    i got a 2 channel amp that is bridgable
    ok this is wot i have been told: + - + - thats wot all amps say, ok my sub is connected to the far left and far right of the + and -, i got told if i connect the two + and - in the middle it will produce more power is this possible or right.
    thanks for your help guys
    VS Acclaim
    Jun 2006
    errrr...
    Usually its the two outermost terminals used, so your setup is correct. (ie channel 1 + with channel 2 -) Your amp will have a diagram how to bridge, follow this and you'll be sweet. This is because modern bridgeable amps have the internals wired up to do so. (something to do with the signal, not 100% but i believe some sort of inverting is involved? Anyone) As to having more power if you bridge channel 1 - with channel 2 +, no
    "The crisis of today is the joke of tomorrow" HG Wells
    VRII Acclaim
    Jul 2005
    As Joe Peeps says, you have it setup correctly. The first + and - are one channel, the second + and - is the second channel. If the amp is bridgeable, the + and - on the outside are the connections you use. Take a look at the user manual, it will run through it.
    dijm8's Avatar
    VZ SS LS3
    Jun 2006
    ok this is wot i mean i knw that i hav my sub connected properly but ive heard that if u bridge the two in the middle like in the picture it will produce 4 times more power is this true??
    thanks
    VK
    Jul 2004
    dijm8's Avatar
    VZ SS LS3
    Jun 2006
    VRII Acclaim
    Jul 2005
    Its already setup internally - you dont need to do anything.
  1. Bridging 4ch amp
    By nath_120 in forum Car Audio
    Last Post: 03-04-2007, 02:42 PM
  2. bridging
    By pr0n in forum Car Audio
    Last Post: 01-03-2007, 12:36 AM
