Results 1 to 5 of 5
Thread: no power to amp!!!
    VS
    Mar 2006
    Unhappy no power to amp!!!
    hi, ive installed a jbl amp and sub recently, using a decent wiring kit, but i cant work out why the amp wont turn on sometimes. ive checked with a multimeter that i hav 12v from battery, and 12v from headunit when swiched on.
    ive noticed its usally in the morning when the car hasnt been started for a few hours. but works fine through the day?
    any thoughts
    btw fuses are also fine
    SweetWagon's Avatar
    SweetWagon is offline booosted
    VS Berlina Wagon Supercharged & VU SS Ute
    Jan 2006
    Springwood NSW
    well if your sure its getting power from the battery and a h/u signal, and the amp's fuses & the inline fuse on the main power wire, that only leaves the earth, make sure it getting good contact with a metallic surface. other then that it would probably be an internal fault on the amp.
    VnExecutive
    Mar 2007
    Cranbourne
    VRII Acclaim
    Jul 2005
    I would go over all of the wiring including fuses etc, making sure there arent any loose connections. Most amps will shut themselves down if they become too hot so check the temp of the amp. Did you check the voltage at the amp when it is not working? If you have 12V there, check the remote signal wire at the amp with reference to earth. You should have 12v there too. If you have 12V power and 12V signal, and the amp doesnt have any life, I would be blaming the amp.
    VS Caprice SII
    Mar 2007
    Northern Suburbs
    happened to me too . its a bad earth try to see what srt of reading your getting with that earth otherwise find another earth point
  1. Options..power seats... power windows??
    By Hairy Eater in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-01-2010, 06:01 PM
  2. Desperatly Seeking Power + Power + More Power
    By kezza_4246 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-10-2007, 10:28 PM
  3. need more power
    By kezza_4246 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 23-09-2005, 09:15 AM
  4. POWER - Real Power
    By MattK in forum V6 Development And Modification
    Last Post: 01-05-2005, 05:10 PM
  5. more power u might help me with
    By Rumbl in forum V6 Development And Modification
    Last Post: 24-01-2005, 09:56 AM
