I have 2 tws306c subs (4 ohm and 400rms) and 2 kenwood KAC-8103D amps (4ohm - 300 rms and 2 ohm - 500 rms).
Im not really sure bout this so looking for some advice, but when the subs are wired together that makes the total load 2 ohm right ?
and when the amps are bridged that makes a total of 1000 watt rms at 2 ohm?
so is it possible to have the subs wired to both amps and still run a 2 ohm load so that they can recieve the full 1000 watt rms ?
sorry if its not clear, if theres any problems ill try to explain it better..thanks in advance...
Not really.
Your best bet is to simply run each sub to it's own amplifier. Either way you are going to be either overpowering the sub or underpowering it.
