Results 1 to 3 of 3
Thread: amp flickering
    car
    Jul 2006
    greensy, melb
    Default amp flickering
    hey all,
    my sub amp in the last couple of days has started flickering on and off non stop and was wondering if you guys would know what it is,
    it only just started the other day when i had to slam on my brakes and now the subby just makes like a pulseing sound as the amp flicks on and off
    "A life lived in fear is a life half lived"
    VRII Acclaim
    Jul 2005
    Most likely a loose connection. You are just going to have to check them all. Power at the battery, power at the amp, ground at the amp, ground at the chassis (especially) and the remote at the amp, remote on the back of the head unit. No-one is going to be able to tell you where it is, you will just have to go searching. Just do a visual inspection and while it is turned on, wiggle the wire, see if it flicks on/off.
    sganro is offline i speak before i think
    yet another VS
    Aug 2005
    NQ
    yeah do what kopper said. I would probably start with the ground cable, as most amp problems i have encountered have been a result of a bad grounding. Make sure the metal to which your ground cable is connected is nice and clean. Get some sandpaper or a wire brush and give it a good clean.
    Otherwise just do the checks that kopper said and you should find it sooner or later
    There are no stupid questions, just stupid people
  1. Flickering lights on cluster
    By tara1 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 06-10-2007, 07:33 PM
  2. Headlights Flickering
    By porkkhunt in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-04-2007, 11:04 AM
  3. Intermittent miss on VP V8 with engine light flickering
    By andynogo in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 03-01-2007, 08:53 PM
  4. flickering alternator light
    By Tony2 in forum Electrical Wiring / Questions
    Last Post: 22-04-2005, 08:46 PM
