Results 1 to 6 of 6
Thread: Removing Door Trims on VK Berlina
    tr3nt's Avatar
    tr3nt is offline trent was 'ere
    VP Calais International 5L
    Sep 2003
    Melbourne, AU
    Default Removing Door Trims on VK Berlina
    Sorry if this is placed in the wrong section peoples... but Santa happened to give me two speakers for the front in the doors, but I haven't the slightest on how to remove the door trim, my brother tried to remove it a while back when the Solex locks were installed, but failed..
    Could someone help in the matter?
    Quote Originally Posted by hakhawk View Post
    if you pay for fuel, ill drive up and drive you around in the bmw. assuming your(hopefully hot) date rides shotgun, and you get the boot, dont worry, its well ventilated if ur dates not so, you can share the boot
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    piece of cake
    Unclip the rear side mirror cover
    unscrew & remove the 2 arm rest retaining screws, hold the arm rest close to the door trim and rotate anti clockwise using the top as a pivot untill it slides easily out of the door trim.
    If its an 84 model, unscrew the interior door lock actuator things, is its an 85 remove the cover trim.
    remove the cover trim on the door opening latch.
    now all that holds the door trim on are the retaining clips in the trim carefully pry the trim away from the door with a scraper if you dont have the proper tool.
    If you want/need detailed photos i cam knock you up something more detailed
    cheers
    Scott
    tr3nt's Avatar
    Sep 2003
    Melbourne, AU
    Thanks for that, it helped! Apart from the window winder, how am I to get that off?
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    oh forgot that
    ok there is a little C clip thatgoes into the winder handle, the handle has 2 slots in it that allows the clip to hit the shaft holding the handle on. the C clip has little tails on each end that will allow you to remove it.
    2 ways
    1 there is a tool that can do it you slide it along under the handle, between the black spacer/washer & the winder handle and it will puch the clip out.
    2. use a clean strong ish rag, um cotton T-shirt material usually works well, thread it under the long part of the handle then between theblack washer/spacer & the handle, while keeping it firm against the handledrag the rag back & forth, this will cause the clip to come out.
    If you need pics let me know i can take a few for you
    cheers
    Scott
    tr3nt's Avatar
    Sep 2003
    Melbourne, AU
    nah thats fine mate, I got it all off etc etc.. but I forgot about the window arm when installing the speakers, now there's two 6" holes in the doors, and I can't do anything about it, oh bah..
    vr 5 speed
    Oct 2003
    i just took mine off to put solex locks on as well and lost the 2 c clips, can you buy these, when i go to put my window up or down my winder falls off.
    cheers
    scitt
  1. Removing 2003 VY door trims
    By madgamer2006 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 15-02-2008, 11:17 AM
  2. Removing door trims
    By Stretchomatic in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-03-2007, 10:06 PM
  3. FS VR/S Berlina door trims
    By seabass in forum Parts And Other Items For Sale
    Last Post: 26-02-2007, 03:55 PM
  4. removing berlina/calais door strips/trims?
    By phat_com in forum VL Holden Commodore (1986 - 1988)
    Last Post: 05-01-2007, 04:02 PM
  5. berlina door trims
    By wicko in forum VL Holden Commodore (1986 - 1988)
    Last Post: 19-11-2005, 02:26 PM
