Results 1 to 8 of 8
Thread: Amp problems
    Apr 2007
    Default Amp problems
    Can anyone help me out, my Pioneer Amp is over heating and really bad.
    calais_cruzin's Avatar
    calais_cruzin is offline Calais_Rattling....
    92 VP Calais 3.8
    May 2006
    Gold Coast
    You could put a computer fan in to cool it, but by i would say that your amp is struggling to power the sub and its getting hot due to it not being big enuff.
    Give sum more details to your system.
    ________________________________________
    impulsesv6's Avatar
    impulsesv6 is offline Alloytec Garage
    A quick Alloytec
    Dec 2006
    brisbane, QUEENSLAND
    how do you know it is overheating?, where is it mounted?, what is the amp powering?,
    could be many things without more info
    Apr 2007
    well some ppl are telling me that its normal, amps heat up and its the casing its designed to do that to draw away the heat from the inside of the amp.
    It on my boot floor and its powering a sub, i bought it all from JB and the guy said that it would do fine
    VN Executive
    Apr 2007
    Wellington, New Zealand
    impulsesv6's Avatar
    A quick Alloytec
    Dec 2006
    2ch or 4ch? how many terminal posts on the sub? you may have it wired up in parallel (if there is 4 posts) not in series causing your amp to cut out in protection mode (1ohm/2ohms/4ohms) , who installed it?
    whats the model numbers of the sub and amp?
    more info on your system is needed
    VRII Acclaim
    Jul 2005
    Maybe try turning the gain down a little. If the gain is set too high, it uses heaps more power without actually being much louder. Turning the gain down a little - might cool it down heaps without affecting the performance. Something quick and easy to try anyway.
    Tasmaniak's Avatar
    Tasmaniak is offline Not a valid input....
    car
    Apr 2005
    how do you know it's overheating? Is it switching itself off or is it getting hot to the touch?
  1. ignition problems or starting problems
    By Vs-AclaimII in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-10-2006, 03:55 PM
  2. VK problems - HELP!
    By Shifty1 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 22-04-2006, 02:25 PM
  3. vn sII into vg what problems
    By rob85 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-02-2006, 07:50 AM
  4. LPG Problems
    By Shounak in forum General
    Last Post: 30-01-2006, 02:19 PM
  5. The VR of VR problems
    By Cowz in forum Electrical Wiring / Questions
    Last Post: 09-05-2005, 11:04 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
