Results 1 to 5 of 5
Thread: Wirinng 2 Amps N False Floor
    MUNTED6 is offline Banned
    vn berlina
    Apr 2007
    Default Wirinng 2 Amps N False Floor
    Hi i was just wondering how do u wire up 2 amps will you need to run to power leads or u cuold just run 1 amp to the battery and som how wire the other to the powered amp? and can anyone tell me how to install a false floor is there any drilling in the boot how would u get wood to stay intact with the ground wen doing sharp turns.? thanx much apriciatte it if som1 cuold answer to this. thanx cheerz
    PRH
    PRH is offline
    vp s utility,and a KENWORTH
    Apr 2007
    Mildura Victoria
    G'day
    AS far as a power supply goes,it depends on the requirement of the amps and the distace as to what size cable you would require,you could use 1 heavy cable ie light battery cable, or 2 smaller cables. 1 single cable would be better on the eye, put it through a plastic sleeve to protect it.
    And to earth it use a piece of the same cable and run an earth from the amps to the body,problem solved.
    Have fun Phillip
    VS Acclaim
    Jun 2006
    Calculate your max current draw from both amps (easy way is to just add up all the fuses) Then run the appropriate gauge cable from the battery to the amps location. Then, you would use a distribution block to split that large wire into two wires going to each amp.
    As to false floor, you could liquid nail a few "stumps" to the boot, and then screw your floor down onto them.
    "The crisis of today is the joke of tomorrow" HG Wells
    2004 Black Vz R8 HSV Clubsport 297kw Gen IV M6
    Apr 2006
    South australia , Adelaide
    Quote Originally Posted by Joe Peeps View Post
    joe peeps can explain this distributation block to me? im guessing by the name it splits up the power evenly between the 2 amps, but still would like to know more. where can u get these/type/price?
    =Brock=
    My Ride
    2004 Phantom Black Vz R8 Hsv Clubsport 297kw 6L Gen IV M6-6 speed, Full black leather -
    azkwazere is offline Ahhh Yes, Ahhh Yes....
    VP 5-SPD / 24-SPD Racer Hybrid
    May 2005
    .....SE Burbs
    Distro blocks are avaliable at any good car audio vending location... cos anywhere from $10 - $100 dollars depending on what they do along with diving current.
    They have a large side in(in this case) say, 2 guage and then 4, 8 guage outs. SOME come fused, some dont. Some have volt meters, some dont. I got al my stuff from JAYCAR. Everything is gold plated, study construction, volt meters and ncily priced.
    aZk.
    Wanted to buy:
    1. T5 V8 Bellhousing and Clutch fork assembly suit VP
    2. V8 Tail Shaft, T5, Suit IRS VP
    3. T5 VB Gear Box
    PM Me if you got what i need...
    Quote Originally Posted by ryno_vrx View Post
    honestly i doubt it will happen cause kanye west will just interrupt Armageddon anyways
  1. True or False - How to tell your commodore has been in an accident?
    By manvr in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 14-04-2006, 10:14 PM
  2. Mounting Amps under false floor
    By Brycestro in forum Car Audio
    Last Post: 24-03-2006, 11:36 AM
  3. true or false doctor bob
    By sting ls2 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 03-07-2005, 01:14 AM
  4. false boot floor
    By chevy_big_block_bro in forum Car Audio
    Last Post: 20-02-2005, 10:51 PM
  5. True Or False
    By blanch in forum VL Holden Commodore (1986 - 1988)
    Last Post: 07-03-2004, 02:12 AM
