hi all ive recently turned ma sub to face inside tha cabin and ive made brakets to hold it so that wen tha middle seat is down its right in tha space so i cant reach threw to tha boot since ive dun this tha boot rattles ( its a vt ss) and on tha parcel shelf tha carpet closest to tha window rattles as well i duno if tha pros of changin tha sub around out way tha cons even though it sounds a hell of alot better inside tha cabin any suggestions on wat can b done to get rid of tha rattle...
BUT IS IT TURBO???
Dynamat the Boot Lid.....
Or use that spray in expanda foam in the Boot lid Braces... (Kinda messy but works)
The parcel shelf rattling against the window is hard to fix... I've been trying to work out an easy fix for ages, but it seems like you need to put some sort of padding (thin foam or reupholster) where the shelf touches the glass. I had a pro tell me I needed to reupholster the whole parcel shelf to fix it.
Yeah i have a similar problem, the boot top rattels from outside the car, inside the car it sounds fine, but out side all you can hear is rattelling with the bass, i have added extra screws to the numberplate which solved some of the problem but it still rattely pretty bad. Would a rubber mat or something under the subs help?
i had the same problem
but it was my number plate, back bumper and garnish
all i did was tighten the screws and with the bumper i made wooden moulds that made the bumper really stiff and not move
since then it doesn rattle anymore.
so try and place a piece of mdf or somethng between what is rattling.
sweet thanx for all tha hellp will try tha suggestion stoneX thats exactly ma main prob i duno how to fix it was thinkin bout velcrove or srews to hold tha carpet down wat do u think
BUT IS IT TURBO???
dynamat tha boot wats that???
BUT IS IT TURBO???
Dynamat creates a "sonic barrier" that restores dynamic range lost to road noise. When you stop road noise and vibration, you clearly hear more of the sounds you want - like music, navigation systems, mobile video and cell phones.
stolen from site
kool thanx
BUT IS IT TURBO???
Be EXTREMELY careful about using expanding foam in your boot lid braces. That can expand too far and actually put small buckles in your boot lid.
Dynamat or Stinger sound deadener.. Its adhesive on one side so its easy to use. Just cut to size and stick.
**aikz
[LOUDDD] Lancer...
wher do i stick tha dynamat
BUT IS IT TURBO???
to the under side of boot lid, everywhere, its stop soudn escaping the car, which stops the rattles.
Dont know it it would help the rattling shelf tho.
But will stop boot rattles
It actually absorbs sound and reflects some too. It adds weight to the metal panels so that they don't vibrate, if they don't vibrate the sound is either reflecting off or being absorbed... In this case it's doing both as the Dynamat is rubbery which absorbs vibrations(sound).
sweet wher do i get this from
BUT IS IT TURBO???
A car audio store, not JB Hifi or Strathfield though.
sweet u rekon autobarn or sumfin like that
BUT IS IT TURBO???
Most of them will, or will be able to order it.
