Results 1 to 6 of 6
Thread: Sound System high pitch sound
    Nov 2004
    Default Sound System high pitch sound
    hey all
    I jsut installed my new stereo:
    6 1/2 inch kenwood 150 watt speakers for the back
    6 1/2 inch pioneer 220 splits
    12 inch JBL sub
    520 watt JBL amp
    Pioneer head unit
    and i seem to be gettin a high pitched ringin tone when i drive or rev the car. When i put my accelarator down the pitch gets higher....
    Does anyone know what could be the problem???
    VSStato8 Guest
    1.If your power lead and rca's are running from front of car together they could cause interference with each other. Solution = run them seperately ie rca's one side power other.
    2.you could have a bad earth somewhere. If you've earthed it to the body somewhere that has paint on it you'll have to rub it off so that it gets a good connection to the body.
    scott_dog_1 Guest
    Nov 2004
    nup ive checked both of those things just mentioned and it is all done right but i still hav the high pitch tone.
    it gets higher as i rev the car.....
    Any more suggestions???
    VT Executive
    Jun 2008
    logically, what part of the electrical system goes faster when the engine revs? i reckon it's an alternator problem.
    Two solutions: one is an rca noise filter, (filters the sound at line-level before it gets to the amps), the other is a power signal noise filter (filters the power between the batteries and the amps, which should kill the noise before it gets there). I used both in my 1971 kingswood because the non-resistored electrics were an audiophile's nightmare; i got repco to order them both in from a brand called aerpro. cost me about $30 for a wiring kit that included the noise filter, an in line fuse and 6 metres of battery cable, all made up ready to go. the con is you can only get them up to 40 amp rating, so they come with 8guage cable, which limits you to under 600 watt amps unless you use capacitors.
    Did that arrogant attitude come with your falcon, or was that an optional extra?
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    Fix the problem, don't try to hide it with a filter. But why are you bumping a 3.5 year old thread anyway?
  1. Stange high pitched sound
    By VLishes in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-03-2006, 08:45 PM
  2. low pitch hissing sound after removing headunit
    By Brycestro in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-02-2006, 11:32 PM
  3. help with sound system...
    By jack.mc in forum Car Audio
    Last Post: 31-10-2005, 09:10 AM
  4. sound system
    By clarky84 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-10-2005, 04:51 PM
  5. just bought sound system, will it sound good
    By pier_one in forum Car Audio
    Last Post: 02-10-2005, 01:27 PM
