Results 1 to 18 of 18
Thread: mounting h/u (vt)
    SweetWagon's Avatar
    SweetWagon is offline booosted
    VS Berlina Wagon Supercharged & VU SS Ute
    Jan 2006
    Springwood NSW
    Default mounting h/u (vt)
    Hi just after opinions in the best way to mount an aftermarket headunit (single din) in a vt? i installed it a while ago but it never been properly secured. I was thinking to rivet the h/u cage to the metal housing inside, then use those keys to remove it, instead of screwing it in like i would normally do. but it is a real tight fit. might have to hammer it out some more
    so how have other people done it? cheers.
    Power is measured in DECIBEL
    wrx884's Avatar
    wrx884 is offline WA's ASR Rep
    VT Commodore Exec/5L VP Calais
    Mar 2006
    Wat r u hammering out? im not sure y u would need 2 as u dont have 2 alter nething wen installing HU's in VT/VXs??? mayb im reading this wrong?
    Check out my ride in progress.... 98 VT V6, V8 Supercar kitted
    Daily toy.... 92 VP Calais 5L
    SweetWagon's Avatar
    Jan 2006
    Springwood NSW
    Quote Originally Posted by wrx884 View Post
    you know the housing that the factory unit clips into. its was a real tight fit with the new one. so i gave it a few taps with the hammer which was enough to get it in, this was a while ago. NOW i want to do secure it properly, its just sitting there ATM. so how have other people mounted them?
    wrx884's Avatar
    Mar 2006
    ahh k weird well mines just clipped in there securly not screwed or riveted didnt think it was nessasary so i didnt bother so cant help ya man sorry
    SweetWagon's Avatar
    Jan 2006
    Springwood NSW
    so nothing is holding it in there? thats how mine is now but i dont like the idea of nothing securing it in (not that it moves anyway), and being able to remove it by just yanking it out. cheers
    wrx884's Avatar
    Mar 2006
    na nothings holding it appart from the cage the unit sits in, its a nice snug fit and it clips n locks into place i mean yer it could b stolen easy enough and wat u wanna do with urs, would b 2 stop ppl from gettin at it but i see it as if ppl have gone as far as breakin into ur car 2 get it they will get ur gear no matter wat ya do, its all covered by insurance so would get it replaced if thats the case.
    im sure all u'd need 2 do tho is pull out some of the dash so u can get enough room there 2 screw or rivet the cage in place
    SweetWagon's Avatar
    Jan 2006
    Springwood NSW
    yeh i gotta pull the center fascia out tomorrow to fix the lighting in the heater controls so ill see how i go riveting the cage in place. cheers mate
    VY SS
    Aug 2004
    SE Victoria
    hmm..... personally i am more or the high-tensile stainless bolt and screw approach.
    even if you car is broken into, it does not mean it needs to be easy to get the unit out.
    plus i hate bashing things.
    VX Calais S1 V6
    Aug 2007
    sydney
    pulling the dash off doesnt give you any extra room. and that steel box is part of the structure of the car.... you could go to the trouble of doing all that but all cd players come out the same so im guessn if sumone was to break into your car chances are they would know how to remove it, if its snug fit which they fit very well then i wouldnt bother trying to secure it.
    SweetWagon's Avatar
    Jan 2006
    Springwood NSW
    yep ended up just wedging the h/u cage in there, then sliding the unit in and using those keys to remove it. now my other problem, removed the 7 globes in heater controls. All blown! im wondering how on earth that happended but theyre not cheap. might have to raid the wreckers.
    wrx884's Avatar
    Mar 2006
    Globes tend 2 do that with the slightest bump or knock if u dont find some at the wreckers u can get some at dick smith or jay car but u need 2 do some re wiring and mayb some soldering 2 fit them in the globe holders coz no1 else supplies them with the holders appart from holden but they rnt cheap speak 2 jesterarts on how to fit them.
    Tho do a test with a test light 1st and see if ur gettin power there somtimes it could b just a fuse and that will tell u straight out if its the globes blown or not
    VK
    Jul 2004
    i did knock mine out a little when fitting the head unit, the cage in the vt was marginally too small. when i get around to it ill take apart the dash and rivet everything in place. Right now it dont move anyway.
    VS Calais
    Aug 2007
    There is a proper mounting kit for a DIN sizes headunit for vt/vx, to fit this you just need to remove the dash surround and fit the kit to the 4 screws that secure the factory basket in. This then allows you to fold the tabs back to secure the h/u in place properly.
    vs commodore sedan
    Jul 2005
  15. #15
    wrx884's Avatar
    Mar 2006
    Quote Originally Posted by mharv20 View Post
    ur factory head unit had 4 screws 2 hold the unit in??? mine u only needed 2 bits of wire from a coat hanger 2 unclicp the whole unit ive never seen a VT/VX with screws in it from factory yet?
  16. #16
    VY SS
    Aug 2004
    SE Victoria
  17. #17
    wrx884's Avatar
    Mar 2006
    thought it read funny wen it said factory basket wen its all after market? but yer i get wat it means sorry mate
  18. #18
    VY SS
    Aug 2004
    SE Victoria
    sure sure, ya wallie! :P
  1. Replies: 0
    Last Post: 07-11-2007, 08:25 PM
  2. Sub mounting
    By Bubbles in forum Car Audio
    Last Post: 03-11-2007, 01:32 PM
  3. mounting sub-box!
    By Troyziee in forum Car Audio
    Last Post: 23-01-2006, 05:01 PM
  4. mounting hu in vx2
    By ilovemyvx in forum Car Audio
    Last Post: 23-12-2005, 05:37 PM
  5. Amp Mounting!
    By raZel in forum Car Audio
    Last Post: 22-09-2005, 07:29 PM
