ey guys
im getting my new h/u on wednesday, and i wanna know how to remove the old h/u (its factory) now i read the sticky but that involves basically removing most of the interior which i dont wanna do... ive notice that its got slots on either side of it can just keys or a coat hanger to pull it out??
or is ther other ways of removing it???
thanks in advance![]()
Basically...... no. The HU is screwed down to the console and you need to remove the trim to get to it.
alrite thanks for that m8, that was 1 thing i didnt want to do was start pulling things apart looks like i'll hav to then
No worries, the upside is once you have done it a few times it gets pretty easy.
can u just take the trans cover off n undo those 5 or so screws to take the plastic surround off or do u have to undo the glovbox n all off??? just looking for a quicker way thats all
Nope not really, you'd more than likely break some screw mounts if you tried to do it without removing anything. It's literally a 15 min job to take the whole lot off anyway.
glovebox doesnt need to be touched.........just the centre console..........very very easy to take apart and put back together.............you may possibly need some spacers so the new head unit doesnt sit too deep in the console.........sometimes you do sometimes you dont..........i did on my Alpine CDA-9856 just so it would be too sunken into the console and look silly.........if you are running it with subs and have a 3 RCA output unit it can be a tight squeeze behind the headunit with RCA's etc
sweet, most likely i wont be havin subs im sik of them, with da money that was spose to get them can get me a s/c or turbo kit or sumthing else more useful
exactly........i have had a JL W3 V3 12" in the boot for a year now and im about ready to tear it all out and just run 6X9's.........just unecessary weight anyway hehehe
um cobez to get to the screws for the h/u brackers you need to remove the console shroud. so the a yes to glovebox and steering column cover.
Yeah I was going to add that, you really need to access those screws on the sides of the console.
You dont have to remove the glove box though... just open it, the screws are accessable, same with the glove box cover, however, its easy to remove so why not...
And its longer than 15mins, that centre console is a bitch to remove unless youve modded it like mine for quick release
I can get you HU out in 20secs flat, quesiton is do you still want ot have interior trim?
aZk.
PS. Read that how to, its really good.
Agreed that guide is damn good, follow it and you can't really go wrong. The bottom screw on the left of the console is a bit tight to get to with the glove box in place, but as you have mentioned above, the glove box is easy to remove, so why not remove it?
all went well 2day took like 10 mins to pull the dash apart much easier then i though, the h/u is f***kn awesome its even got a rev guage on it :P so i dnt need a tacho ne more haha, only problem is that its not mounted yet which is gettin dun friday for a low cost of $40 bucks at straithfeld
i cud but its a $900 h/u so i dnt wanna start drilling in ther, if i get sum 1 else to do it if they ### up ther gonna pay 4 a new 1 :P
what is it? you dont need to take the drill anywhere near to h/u. just line the stocko brackets from the old h/u onto the new one. easier if you put them side-by-side and then mark the new holes on the brackets. drill, done!! , from memery you only need to drill one hole in each bracket and the other should line up.
Power is measured in DECIBEL
its a pioneer DEHP8850MP, yeh u wud only need 1 hole, i'll hav another look 2mw n decide wot to do frm ther... i cud always chuck sum cardboard in the gaps to keep it still :P haha
Crikey, I hope you have it listed on your insurance! You're just asking for it to be nabbed that way.
