okay just a quick question do you wire up Dual voice subs the same as you would Single or is there a speical way to do it ???
haha sorry dude it isnt that quick to explain but...there are 2 ways to wire a dvc sub, parallel or in a series. If you want to wire in parallel you would run the positive and negative terminals from your amp to the positive and negative terminals on ur sub just like normal except you would run +wire to + on coil 1 and -wire to - on coil 2 and then just run a short peice of wire connecting + to + and - to - etc. this is how you would usually connect ur sub and wiring it this way will half the impendance, if each coil is rated at 4ohms the sub will be set at 2 ohms.
In a series install you would be running +wire to + on coil 1 and -wire to - on coil 2 then run just 1 wire connecting + to - on the other terminals, wiring this way will double your impendance, if each coil is rated at 4ohms ur sub will be set at 8 ohms,
hope this answers ur question
my mates dvc sub had 5 ways to wire it the ones above and some other ways to run more than one amp into it ill get the instructions back it was on the template for the hole
