Results 1 to 7 of 7
Thread: Best amp to run 2 of these together?
    fabz's Avatar
    fabz is offline I Can Do Science Me
    Blown V6 VT commodore 5 speed
    Jul 2005
    In My Car!!
    Default Best amp to run 2 of these together?
    FLAME EXCURSION SERIES x 2 10"
    PHAT 2” Foam Surround
    Non-Pressed, Non-Transfer Paper Cone
    KM3’ Coated for Virtually No Cone Distortion
    Single 4 Ohm VOICE COIL
    Multi-connect Lug Lock Terminals
    Spec see attached file and yes they are 10"
    Cheers.
    Attached Thumbnails Attached Thumbnails Best amp to run 2 of these together?-flameexcursionspecs07.jpg
    .:Blown VT V6, DAJ37:.
    SweetWagon's Avatar
    SweetWagon is offline booosted
    VS Berlina Wagon Supercharged & VU SS Ute
    Jan 2006
    Springwood NSW
    well for starters whats your budget? There are heaps of amps capable of running those but prices vary significantly. But basically you will be looking at a monoblock, ~800wrms, 2 Ohm stable..
    Power is measured in DECIBEL
    fabz's Avatar
    Jul 2005
    In My Car!!
    not fazed on price i just want a good one. maybe around the 500 mark? Can you list some types so i can look them up? that would be great cheers.
    wrx884's Avatar
    wrx884 is offline WA's ASR Rep
    VT Commodore Exec/5L VP Calais
    Mar 2006
    u want types of amps? look in the thread below that was posted not long ago lol (want 2 see wat ur amp looks like inside)
    Check out my ride in progress.... 98 VT V6, V8 Supercar kitted
    Daily toy.... 92 VP Calais 5L
    VY SS
    Aug 2004
    SE Victoria
    well you will either be looking at something from the jaycar range if you want it for under $500. probably the 400 or 800 monoblocks or 2 of the more powerfor 2 channels (around 550wrms bridged)
    after that i would extend your budget to above $800 and have a look at rockford.
    Mar 2007
    And then there is Audison, Rainbow, Hertz, Treo, DLS and others .
    I have a few amps in stock which will run those woofers nicely.
    Pm me if u like.
    George
    VS Calais
    Aug 2007
    Mate i would look at an Alpine PDX 1.600. which run at 600 rms. This amp and the whole PDX Range produce the same power at both 4 & 2 Ohm. Set your 2 4ohm subs up to run 2ohm and you will be fine. these are a little over the $500 mark but are an efficient and compact amp.
