how to reset vx acclaim radio
rkington
VX Acclaim
Guys, just bought a 2002 VX and I have the radio code but I am unsure how to punch the code in to start the radio..can anyone walk me through what is probably a simple process!
sganro
i speak before i think
NQ
yet another VS
Not sure if the vx one will be the same as the vs but this is how to do it on a vs. Firstly, turn your acc. on to give the stereo power. If the code needs to be put in, teh stereo wont do anything when acc. are turned on. Just punch in the code on the number pad. Each time you press a number, it should show up on the screen. Once you have put them all in the stereo should come to life.
Its as easy as that on the VS's so hopefully that will help you get yours going. Otherwise someone with a vt/vx should be able to give you a better answer
rkington
VX Acclaim
thanks
Thanks for that ...will give it a go tonight.
Ray
garfa
37
SE Victoria
VY SS
or the proceedure will be in the user manual.
