Page 1 of 2 12 LastLast
Results 1 to 25 of 30
Thread: Removing VT window winder???
    VT Commodore
    Oct 2006
    Default Removing VT window winder???
    How do I remove the VT window winder, I am installing new speakers and need to take it off?
    Cheers,
    Semtex
    vy_storm's Avatar
    vy_storm is offline just another moderator...
    VE Calais V 6L
    May 2005
    the burbs of Adelaide
    We tend to get a thread on this almost every month. Either head down to your local auto parts store and buy a window winder removal tool or attempt to remove the circlip that holds the back of the handle onto the winder shaft with a screw driver or a rag.
    Here's a link that might give you an idea;
    Removing window winder handles » AUTOFIX.COM.AU
    | evaN |'s Avatar
    | evaN | is offline mmm bass
    VT
    May 2006
    SE Melbourne
    I tried the rag method but it gave me the ****s. I used 2 small screw drivers to pry open the clips and I had all window winders off in under 10mins
    VY SS
    Aug 2004
    SE Victoria
    VT Commodore
    Oct 2006
    SweetWagon's Avatar
    SweetWagon is offline booosted
    VS Berlina Wagon Supercharged & VU SS Ute
    Jan 2006
    Springwood NSW
    Quote Originally Posted by Semtex View Post
    i cant see the clips what exactly am i prying off?
    semtex
    it is between the handle and the spacer, you need to push the trim back to see it. I found a rag works the best, slide it between the handle and spacer and it should catch the clip.
    Power is measured in DECIBEL
    | evaN |'s Avatar
    VT
    May 2006
    SE Melbourne
    Quote Originally Posted by garfa View Post
    fork works better than screw drivers. cut off all but 1 prong.
    but then i'll be killing an innnocent fork lol
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    It will be forked....
    Visit my Facebook page
    VY SS
    Aug 2004
    SE Victoria
    fork the fork, works well and easier than a cloth, banged my hands too many times, stupid clothes.....................
    VT Commodore
    Oct 2006
    ok ok i bought a winder removal tool. i press down between winder and spacer i feel something happening, now what do i pull handle off. I am not too sure about this dont wanna break anything.
    Let me know of your experience and ideas.
    Semtex
    Also let me know how to put handle back on cheers
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    I used the rag method to pop the clip out on the weekend on my VS, very easy, and free.
    To put the handle back on, push the clip back into the handle so the prongs point toward knob, then just push back onto the shaft.
    VT Commodore
    Oct 2006
    ok can u tell me step by step
    do u pull it off after u used the rag??? and also how to put on i actually bought a tool for it feel that it loosens but not sure how to get it off
    thanks mate
    Semtex
    SweetWagon's Avatar
    Jan 2006
    Springwood NSW
    a thin wire clip should pop out, you have to pry the spacer back so u can see what your doing!! and push the tool against the open end of the clip. not that hard. after that the winder will easily slide off.
    VT Commodore
    Oct 2006
  15. #15
    VT Commodore
    Oct 2006
  16. #16
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    No. The back of the clip will be visible between the spacer and the handle once you have pushed the tool in. You push it from the knob side, between the handle and the spacer as said.
  17. #17
    SweetWagon's Avatar
    Jan 2006
    Springwood NSW
    do u need to wind window down first>?
    not unless you want your window to be down until you put it back on??
    heres a pic of the clip that hold the handle on the shaft,
    Attached Thumbnails Attached Thumbnails Removing VT window winder???-e3_1.jpg
  18. #18
    azzfox's Avatar
    azzfox is offline slideways
    VN SV3800 #012, N13
    Sep 2005
    Yarra Valley, VIC
    nope.. and to put it back on just insert the circlip back onto the winder and push it onto the shaft till it locks back in place. once you get the winder off you will see how simple it goes back on
    My (ex)Ride
    Quote Originally Posted by ari666 View Post
    LMAO!!! bracelets!!! and neck chains?!?!? they are as gay as aids.
    Quote Originally Posted by Not_An_Abba_Fan View Post
    Nice 4 year old thread dig dude....got a permit to mine that deep?
  19. #19
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Judging by his questions, nothing is simple for him....
  20. #20
    VY SS
    Aug 2004
    SE Victoria
    now now be nice............
    maybe get a haynes/gregories manual for your car semtex. it has heaps of photos and about the only thing it doesn't go into if rebuilding a diff, rebuilding an auto trans and heater cores.
  21. #21
    toyota lexcen - vr.
    Jan 2009
    victor harbor
    another easy method is to get a small screw driver, and bend it.
    worked a treat.
  22. #22
    BensVR's Avatar
    BensVR is offline BensVR
    VR ACCLAIM
    Dec 2008
    Peterborough SA
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    OK guys hes already bought the removal tool, and if used properly it should work better than a fork or rag/cloth.
    1. Insert the tool in between the door handle and the spacer (round plastic washer thing).
    2. Put the tool all the way in untill it wont go any further.
    3. Just move the removal tool around in a circle untill a little circlip either pops out or becomes dislodged (you should be able to part of it).
    Look, heres two pics that explain where to insert the tool and what the winder looks like
    Attached Thumbnails Attached Thumbnails Removing VT window winder???-image04.jpg   Removing VT window winder???-image05.jpg
  24. #24
    dh
    Aug 2009
    hey guys, in my brothers 98vt wagon there is no circlips, i have never seen anything like this and cant get door trim off till window winder is off. please help!
  25. #25
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    Are you sure? The only other way i can think they are held on is with glue.
    150db in a commodore =
  1. removing window winder handles
    By peeete in forum General
    Last Post: 29-06-2006, 03:04 PM
  2. HELP: Removing Vy Window Winder
    By wanted7 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 01-05-2006, 07:59 PM
  3. How do u get the window winder off?
    By veclubby in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-02-2006, 05:24 PM
  4. Removing Window Winder. VN
    By PaRaDoX in forum General
    Last Post: 19-11-2005, 05:21 AM
  5. Removing Window Winder
    By bundy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-10-2004, 05:13 PM
