Results 1 to 19 of 19
Thread: cutting out
    2004 Black Vz R8 HSV Clubsport 297kw Gen IV M6
    Apr 2006
    South australia , Adelaide
    Default cutting out
    I just bought a new Alpine V12 mono block amp...and after hooking it all up...when i crank it to around 26 (out of 30) it all cuts out..not sure if its the amp or the subs...but the 2 subs are 350RMS each, and the amp is 1000RMS..just wondering why it would be cutting out at high volume, any help?
    =Brock=
    My Ride
    2004 Phantom Black Vz R8 Hsv Clubsport 297kw 6L Gen IV M6-6 speed, Full black leather -
    sganro is offline i speak before i think
    yet another VS
    Aug 2005
    NQ
    Its probably the amp going into the protection mode. If it runs fine at normal volumes and only cuts out when its really cranked than i would say its the amp tripping out on protection. There should be a light on the amp showing when it hits protection.
    There are no stupid questions, just stupid people
    colk is offline VZ 3.6
    VZ 3.6 Exec
    Aug 2007
    Im no pro but have done a few installations (more of a hobbiest).
    I would try upgrading the earth from the amp, also the earth from the battery. This helped with my old VP that used to cut out after long periods, it also solved head lights dimming. Are they DVC and are they wired in parallel? If they are it would be putting a 1ohm load on the Amp, this would draw allot of curent so earths may help?
    Any other opinions anyone??
    Mar 2007
    I would first of all look at your installation and how those woofers are wired up.
    And second i would check your gains and make sure you didnt think it was a volume button and cranked it right up without thinking about tuning it correctly first .
    Apr 2006
    nah there are no buttons/guages and gains or anything on this amp...its just plug and play..i might try new earth wires first
    =Brock=
    My Ride
    Mar 2007
    Sorry man the amp does have gains, if its the one with the digital display then undo the cover and the control buttons are there.
    There is no such thing as plug and play, every amp has at least a gain sensitivity button.
    Apr 2006
    oh ok, my bad, so its underneath the white cover??
    will this void warranty?
    =Brock=
    My Ride
    '97 VS Commodore + '98 E36
    Apr 2005
    Mar 2007
    Nah just get an allen key if the amp doesnt come with it undo the two screws and u will find the buttons are behind the white panel.
    I would still fix your earth though because i reckon you got it earthed to the parcel shelf or the boot hinge .
    Thats where most people earth there DIY amps.
    Oct 2007
    Yeh, i have had similar problems with the alpine amps as well due to their high current draw a couple of tips i have found that cure the prob.
    1. Check that both power and earth cables are of sufficient gauge
    - 8AWG for 1 - 400 WRMS
    - 4AWG for 400 - 600 WRMS
    - 2AWG for 600 - 1000 WRMS
    - 0AWG for 100 and upwards
    2. Try grounding direct to car body shell or even mounts to chassis.
    3. Even check that the remote turn on wire is connect properly and to the headunit or relay setup.
    | evaN |'s Avatar
    | evaN | is offline mmm bass
    VT
    May 2006
    SE Melbourne
    Quote Originally Posted by underoneskin View Post
    Those RMS values seem to low for the wire size. Im running a jaycar monoblock, 1500wrms and its recommended wire size is 2guage
    Apr 2006
    ok thanks for ur help guys, ill sort of the following and let use know
    =Brock=
    My Ride
    VY SS
    Aug 2004
    SE Victoria
    thats great that you can recommend power through a wire with out specifying the length or the types of amplifier class!
    amazing, next people might start to cure blindness by snapping their fingers............
    current capacity is dependiant on length.
    Oct 2007
    azzfox's Avatar
    azzfox is offline slideways
    VN SV3800 #012, N13
    Sep 2005
    Yarra Valley, VIC
    You cant give a guide based on wrms power figures. As garfa said about amplifer classes, some amps will draw more current than others.. this is called efficiency. The best way to judge which gauge is best suited for your setup is by its current capacity and how much current your system draws.
    My (ex)Ride
    Quote Originally Posted by ari666 View Post
    LMAO!!! bracelets!!! and neck chains?!?!? they are as gay as aids.
    Quote Originally Posted by Not_An_Abba_Fan View Post
    Nice 4 year old thread dig dude....got a permit to mine that deep?
  16. #16
    VY SS
    Aug 2004
    SE Victoria
    you cant give a current capacity of a wire with out specifying lenght. there is no general rule.
  17. #17
    VK
    Jul 2004
    Quote Originally Posted by garfa View Post
    i tend to agree, however would the resistance caused by this length of wire have a menial impact on the system? I guess if you really get down to it, it definitely can't be overlooked, however from a car audio perspective i wouldn't think it'd have a huge impact?
  18. #18
    Tasmaniak's Avatar
    Tasmaniak is offline Not a valid input....
    car
    Apr 2005
    to the OP one thing you should tell us (although I'm betting it is the gains also) is what is the impedance rating at 1000wrms? Also, what impedance are the subs? Are they wired in series or parrallel?
  19. #19
    wh33lzz's Avatar
    wh33lzz is offline Custom Audio
    VT Executive
    Nov 2007
    Whoa boy!
    Set those gains correctly first!!! you will kill your subs otherwise,
    also make sure the load presented to the amp is within its safe range.
    When using 2 woofers, you need to know the voice coil configurations to tell exactly how to wire them properly, are they dual 2Ohm or Dual 4 Ohm voice coils? or single 4Ohm or 2Ohm?
    are they wired in series or parallel?
    These 3 things are all important to the setups safety and longevity plus how it sounds.
    You want the maximum for your gear mate, setup is where its at.
    Overengineering is FUN
    Custom Car Audio
    Morel Alpine MB Quart JL Audio
  1. VN V6 cutting out
    By Shortstuff in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-01-2009, 04:35 PM
  2. VP Air Con cutting out
    By VP-Matty in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-06-2008, 10:18 AM
  3. Amp keeps cutting out?? PLS HELP
    By Holdenboy_VS in forum Car Audio
    Last Post: 17-01-2007, 10:57 PM
  4. Amp cutting out!!
    By donz in forum Car Audio
    Last Post: 01-11-2006, 08:37 AM
  5. VX a/c cutting out
    By VX_GIANTZ in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 31-10-2005, 10:24 PM
