Hi guys just looking at a diagram for my response jaycar splits and looking at how the wires from the tweeter to the crossover go 4 ways??? This confuses me. One wire (-) goes to the (-) on the crossover. Then the positive on the tweeter goes to +3dB +0dB and a -3dB which in total shows four wires connecting when I thought it was as simple as putting a (-) and a (+), obviously not. Can someone with some tech know how tell me if i need to connect all four wires or are these last 3 options.
Thx
Semtex![]()
it only goes to one of those 3, start with it in the +0db spot, and see if you like the sound they put out, if its too quiet, go the +3, if its too loud, go the -3
ok thanks. also where is the best spot to put crossovers within the cabin. I cant seem to put them hidden away anywhere in the air vents as described by other ppl. Let me know what your ideas are people.
Semtex![]()
I am installing these myself at the moment. The only place I can think of is to run the wiring to the left front side of the car and just screw both of the crossovers under the glovebox (from what I can see so far, they wouldn't be seen)
50LTRv8
under the glovebox and steering column for each side.
