Results 1 to 19 of 19
Thread: Question re blaupunkt frm vy into vz
    VZ
    Nov 2007
    Default Question re blaupunkt frm vy into vz
    I have been given the opportunity to obtain a standard 6 stacker from a VY to put into a VZ (to keep she who must be obeyed happy). I have had contact with my local holden dealer who was not much help, I know it fits and is easy to remove etc, but my question is will it be compatable with the VZ? I have read that the BCM will need to be reprogrammed to recognise the new unit, but the local dealer indicated that he thinks that it will not work. He also stated that they have never done one before and wants the charge the full hourly rate (about $80) to just have a look at it and see if he can do it!!! Any suggestions???
    andyman's Avatar
    andyman is offline The Only 6sp VZ Wagon
    2012 BT50 4x4, 84 Hilux 4x4 & 05 Husky TE450
    Mar 2005
    Nowra, NSW
    should swap over and should only need the security pin
    EASTERN CREEK JCNSW 2009
    Quote Originally Posted by Commydoor
    First of all your words cannot harm me cause my ego is like a shield of steel.
    Phreddy's Avatar
    Phreddy is offline Bye SV6 - still love you
    VS-II Statey-8
    Apr 2005
    W-Sydney NSW
    +1 for Andyman.
    It will slot straight in, and all you need to do is key the PIN for the unit and you're away. Just make sure you get the PIN for the unit you're buying! If you need to go to Holden for it, you're in for a very LARGE PITA.
    Cheerz.
    New look ASR Website online now!!
    www.asr-audio.com.au
    Interior lighting and audio specialties
    for VT/VX & VY/VZ Commodore / Monaro
    NOW VE DASH LIGHTING CONVERSIONS!!
    PLUS TECH2 DIAGNOSTIC SERVICES
    JBL Car Audio dealer
    Silver surfer is offline Banned
    04 VY Executive
    May 2007
    holden charge $30 for the pin code had to get mine the other day for the guy who bought it off me. luckily the chick was nice and gave it to me for nothing.
    VY SS
    Aug 2004
    SE Victoria
    Quote Originally Posted by Silver surfer View Post
    did you need to pay $30 for her number, eh?
    VZ
    Nov 2007
    Default More help needed
    Following on from my original post, the saga continues. I have the pn for the six stacker I got to replace my single one. PIN didnt work, contacted holden again and they are adament that a VY unit will not got into a VZ due to the way a vz is wired!!! Can any body help??? They said nothing can be done other then to sell the unit to someone with a VY!!!!!!
    Doctor Bob's Avatar
    Doctor Bob is offline Grandpa
    VT V6 Exec & VN V6 Exec
    May 2004
    Mornington Peninsula
    the wiring of the connectors is identical, exactly what happened when you tried to fire it up?
    Rob
    VZ
    Nov 2007
    the unit will power up, that stacker mechanism will go thru it's motions, then it asks for the pin, it will not accept the pin, even though it is definitely the right pin.
    Phreddy's Avatar
    VS-II Statey-8
    Apr 2005
    W-Sydney NSW
    Hmmm - your procedure is perfect. I wonder if maybe you weren't give the "radio PIN", but the "Security code" from the original wallet card. (they are both 4 digit numbers, maybe you were given the wrong one?)
    As for the dealer telling you that the wiring is different - that sounds to me like a cop-out. (if Doc Bob says they're the same, then they're the same!!) I actually had a dealer tell me once that the units from VY and VZ are physically a different size, and won't fit in the cradle! That's up to about the usual standard of the advice from dealers anyway. I take what they say with a very LARGE grain of salt.
    And I guess now the bloke who sold it to you doesn't want to know??
    Phreddy's Avatar
    VS-II Statey-8
    Apr 2005
    W-Sydney NSW
    Hmmm - sorry, double post....
    Doctor Bob's Avatar
    May 2004
    Quote Originally Posted by Menz View Post
    when you say it wont accept the pin what happens?
    VZ
    Nov 2007
    It just reverts to the pin entry screen with login 2 or 3 depending on how many times i've tried, after three attempts it locks you out from trying for one hour.
    VZ
    Nov 2007
    The guy I bought it from, got the pin double checked with the dealer he got his maloo from, so he has been good so far.
    Doctor Bob's Avatar
    May 2004
    you may need to confirm the pin by getting the serial number on the unit checked.
    if you can get me the vin from the original vehicle it came from & the serial number off the radio i can probably check if it is correct.
    the only other possibility is that the VZ BCM handles the pin differently. if the pin is different in the bcm (needs to be programmed with tech2) it may disable the radio, but i dont think so normally it just means the pin needs to be entered if the unit has been powered down.
    i would suspect the pin is wrong, the unit may have been changed & the database not updated.
    Rob
  15. #15
    VZ Executive
    Sep 2007
    VZ
    Nov 2007
    I am in the process of getting the vin number, so will repost as soon as I have got it. cheers
  17. #17
    VY II Commodore S
    Dec 2007
    Newcastle
    Default how much?
    Hey mate, Cant help, but was wondering how much you managed to get it for. I was wanting to put the 6 stack version in my VY. Has anyone seen one for sale recenly?
  18. #18
    VZ
    Nov 2007
    Have finally got the VIN, it's 6G1YK42F84L189843 and the serail number of the unit is BP 2256 41241707, the other numbers on the unit are LP 8 635 123 247 2 as well as 92 118 704. this last one is on a sticker on the back of the unit. cheers
  19. #19
    VZ
    Nov 2007
    Hey Wmov, I got it for $226. Thing is, if I had a Vy it would have powered straight up! D'oh. I will sell it if I cant get it to work in the VZ!!!
  1. Stock VZ SV6 HU (Blaupunkt) question
    By ncielens in forum Car Audio
    Last Post: 09-10-2006, 01:45 PM
  2. Blaupunkt into VT
    By 02VYSS in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 21-04-2006, 11:48 AM
  3. Blaupunkt wiring
    By VRbeast in forum Electrical Wiring / Questions
    Last Post: 18-02-2006, 02:49 AM
  4. VY Six Disc Blaupunkt (Any Around)
    By ScottB_33 in forum Swap / Wanted to Buy / Trade
    Last Post: 29-01-2006, 05:49 PM
  5. Blaupunkt Specs???
    By Morgasshk in forum Car Audio
    Last Post: 14-09-2005, 04:52 PM
