wanting to install 6x9's into the parcel shelf and i cant find any speaker wires that would connect to them, do i just need to extend the wires from the rear doors long enough to reach the parcel shelf or is there seperate wires for the parcel shelf
if u didnt have speakers in there b4 no there wont b and urs bein an exec i doubt it u can tap into the wires just b4 they run through the rubber boot of the rear doors
will the speakers be in addition to the rear door speakers? (eg 6 speakers) if so you cant do that with your h/u.
you can just run in series u will just have to fad it to the rear more and up the volume i just did it at tafe. unless u buy the amp holden uses or another amp for them
will sound VERY BAD from a stock h/u. the already weak signal will be even worse.
besides there really is not much point to run 6 speakers.
in my vp exec (..which i dont know if it is the same as the VR), the vehicle wiring loom to the head has the wires for 4 speakers but the ones for the rears only go as far as to a connector behind the kick panel on the drivers side (near your right foot). So you will need to run the wires down the side of the car, pull out the back seat (easy) and thru an existing hole in the metal work (there are already wires for other things - lights etc - going the same way). A bit frustrating as another $1 spent at build time would provide them.... but thats ok. cheers pete.
