Results 1 to 5 of 5
Thread: vent air speed.
    VY SS
    Aug 2004
    SE Victoria
    Default vent air speed.
    hi all,
    just wanting to know if there is a lower limit to the speed of the air coming from a port?
    i know to keep it under about 30 m/s but when does the woofer tend to bottom out from no back pressure?
    thnx
    Luke0011 is offline Car Audio Installer
    VZ Berlina 2005
    Jan 2007
    Below the frequency of the tuned port specification the woofer is guided only by its mechanical abilities. Below this frequency the sub can bottom out. Cheers Garth long time no see!!!!
    VY SS
    Aug 2004
    SE Victoria
    hey man, where have you been? holidays for a few months?
    didn't quiet understand you, could you expand a bit?
    wh33lzz's Avatar
    wh33lzz is offline Custom Audio
    VT Executive
    Nov 2007
    The tuning frequency of a ported subbox is as low as you want the sub to play at 0Db you want roll off (-3 or 6Db or more if possible, using a subsonc filter can help here) under this as the sub will mechanically bottom out due to lack of acoustical suspension (air pressure behind the subs cone) under the port tuning frequency.
    Bottom line is you will hear port chuffing stop, and your woofer may die if over excurted below this point.
    Overengineering is FUN
    Custom Car Audio
    Morel Alpine MB Quart JL Audio
    VY SS
    Aug 2004
    SE Victoria
    ok, so pretty much i can make the port/s as big as i want.
    wont it eventually be just like having the woofer in a free air set up?
    so i could chuck in a few 4 inch ports with my 12 inch woofer and not be too worried as long as i have my filters set up correctly as always.
  1. VZ fender Vent on a VY
    By XXFR in forum VY Holden Commodore (2002 - 2004)
    Last Post: 07-05-2007, 01:39 PM
  2. VZ indicator air vent
    By turkey nuts in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 29-11-2006, 04:37 PM
  3. VS Vent Prob
    By dmitch in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-09-2006, 07:03 PM
  4. vent control
    By micko in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-04-2004, 07:47 AM
  5. Splein Vent
    By mickey in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 12-03-2004, 03:54 PM
