Results 1 to 3 of 3
Thread: Help
    94 vr ss
    Oct 2007
    Default Help
    ok i got a dvd player and i hooked up the constant power wire but on the small screen it has when the car is off acc off all the time will send my battery flat and wood my starter motor sorta stiken make a difference
    wh33lzz's Avatar
    wh33lzz is offline Custom Audio
    VT Executive
    Nov 2007
    Yeah def a starter motor problem I would think.
    Did you wire the constant and switched power to the Screen or Head unit running it?
    If you havent wired it switched (accessories) it *may* be draining the battery a little, although I'd start at fixing the starter motor first and troubleshooting from there.
    94 vr ss
    Oct 2007
    yeh nah i took the risk and she was fine this morening tnxs
