Results 1 to 12 of 12
Thread: VS Series II Stereo Install..
    VS Series II
    Nov 2007
    Newcastle
    Default VS Series II Stereo Install..
    hi all,
    Ive just basically inherited a VS from my old man so I'm looking to put a CD player in it. Nothing too fancy but just so i dont have to listen to add's on the radio.
    Anyways, after googling the subject of installs for ages, I've found it is possible and seems easy enough to install a radio. But I heard somewhere In the myst that if you unplug the battery the computer has some trouble, or you need some code or something like that? Is that the same with installing a cd player?
    Any info in this security or computer thing would be good, as I dont want to pay top $$ for someone to install it.
    Just a bit worried, dont wanna stuff up the car, its not exactly mine yet, but will be very soon.
    thanks
    SweetWagon's Avatar
    SweetWagon is offline booosted
    VS Berlina Wagon Supercharged & VU SS Ute
    Jan 2006
    Springwood NSW
    The security code only applies to the factory headunit when its reset ie. disconnected/dead battery... If your removing and replacing it then you wont need the code
    there is a good install guide at the top of this section.
    Power is measured in DECIBEL
    Subaru Liberty
    Feb 2007
    Quote Originally Posted by inais View Post
    The security code is only for the standard radio/cassette player. If you wanted to, you could throw out the security code if you weren't going to use the radio/cassette player any more.
    Just as long as you disconnect the battery before you start the install, then you will be fine. Not sure if the immobiliser system will be affected by the disconnection from power though...
    VS Series II
    Nov 2007
    Newcastle
    so the only electric thing in the car affected by d/c the battery is the standard radio which I wont use again most likely?
    Nothing else?
    Thanks for that guys, its appreciated
    VS Series II
    Nov 2007
    Newcastle
    sorry to double post.. that guide is great! tho i thought it would be so much more simpler.
    Just curious tho, how much would it cost for a shop to do it? I dont wanna get all the heater and air con stuff mixed up.
    It's alot more complicated than the old corolla i had.
    SweetWagon's Avatar
    Jan 2006
    Springwood NSW
    depends where you go. try avoid stathfields/jb etc.. they tend to bodge up jobs. I have seen it all too often so steer clear. go to a reputable car audio shop or auto electrician instead. im guessing around to 100 mark for headunit install...
    azzfox's Avatar
    azzfox is offline slideways
    VN SV3800 #012, N13
    Sep 2005
    Yarra Valley, VIC
    give it a go, I was able to do it before I knew anything about commodores. you cant mix up the heater stuff. the two plugs on the back and vaccume hoses only go on one way.
    My (ex)Ride
    Quote Originally Posted by ari666 View Post
    LMAO!!! bracelets!!! and neck chains?!?!? they are as gay as aids.
    Quote Originally Posted by Not_An_Abba_Fan View Post
    Nice 4 year old thread dig dude....got a permit to mine that deep?
    VS Acclaim
    Jun 2006
    cost about $80 bucks but as above give it a go. I was an absolute monkey NFI when i first discovered the guide on this site, got me through easy enough so have a go mate!
    "The crisis of today is the joke of tomorrow" HG Wells
    VS Series II
    Nov 2007
    Newcastle
    alright, I'm gunna give it ago, have nothing better to do with my days, working nights...
    but if anything goes wrong, you can be sure to hear from me lol...
    I dont think much will go wrong, but if it does.
    thanks for all your help guys/gals if there are any
    azzfox's Avatar
    VN SV3800 #012, N13
    Sep 2005
    Yarra Valley, VIC
    no probs, helps here if you need it.
    TIP: if you want to use stock mounting brackets, drill a new hole in between the two front existing holes on the brackets. this way the head unit will sit perfectly inline with the dash surroundings one screw on each side of the unit will hold it fine, but if you want two then follow these steps:
    *mark near the top of the head unit with a texta where another hole on the head unit is.
    *screw the brackets to head unit using the new holes you drilled and line the top of the brackets parrellel with the top of the head unit.
    *mark a dot on the bracket inline with the texta mark you made.
    *drill another hole.
    (use a ruler to make everything square)
    My (ex)Ride
    Subaru Liberty
    Feb 2007
    Install it yourself. The guide posted is excellent. I installed mine a few weeks ago, and I have zero knowledge of cars, electrics, heaters, or pulling apart bits of the dash. And mine works perfectly.
    VRII Acclaim
    Jul 2005
    Have a digital camera handy while your doing it, or failing that a camera phone. If your stuck or not sure just take a pic, pop it on here and we will be able to answer your question really easily.
  1. stereo/amp install VS
    By WiLo in forum Car Audio
    Last Post: 25-05-2006, 10:14 PM
  2. VT Stereo Install
    By RobbyKelly in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-03-2006, 07:54 AM
  3. VC Stereo Install Help
    By Goon in forum Car Audio
    Last Post: 24-02-2006, 09:54 AM
  4. Another VP stereo install, need help.
    By hollywood_VP in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-06-2005, 12:31 AM
  5. Ute Stereo Install
    By emoo in forum Car Audio
    Last Post: 27-05-2005, 02:54 PM
