Page 1 of 2 12 LastLast
Results 1 to 25 of 34
Thread: where to put amp?
    vs 96 acclaim
    Nov 2007
    Default where to put amp?
    i've just hooked up an amp and kicker sub in my boot. But wheres the best place to mount the amp? preferably in the boot
    Haydz's Avatar
    Haydz is offline 346 cu/in
    VS UTE LS1 T56
    Nov 2007
    Liverpool.Sydney,NSW
    dufus is offline Donating Member
    rickshaw
    Jun 2006
    Haydz's Avatar
    VS UTE LS1 T56
    Nov 2007
    but a tip. dont drill the holes right through other wise if you change amps. you will have holes there for the air to escape. it will sound dodgy.
    rickshaw
    Jun 2006
    Quote Originally Posted by Haydz View Post
    Thats nothing a couple of plugs wont fix
    Haydz's Avatar
    VS UTE LS1 T56
    Nov 2007
    still may as well save stuffing it up for a few words that can help him out.
    vp executive
    Nov 2007
    lakes entrance VIC
    ive heard that the bass can wreck a sub if it's right in front or mounted to the box as it rattles component's loose or something correct if ive been told a porky as i had the same idea of mounting it to the box
    [SIGPIC][/SIGPIC]
    Screw the icecream...
    Who wants a moustache ride?
    azzfox's Avatar
    azzfox is offline slideways
    VN SV3800 #012, N13
    Sep 2005
    Yarra Valley, VIC
    mounting to the enclosure will reduce the life of the amp. the excessive vibration will increase the risk of components failing.
    My (ex)Ride
    Quote Originally Posted by ari666 View Post
    LMAO!!! bracelets!!! and neck chains?!?!? they are as gay as aids.
    Quote Originally Posted by Not_An_Abba_Fan View Post
    Nice 4 year old thread dig dude....got a permit to mine that deep?
    VY SS
    Aug 2004
    SE Victoria
    also it makes it MUCH more easy to nick it all. kinda like 2 for the effort of one really.......
    but if it keeps the thieves away from my car then go for it! j/k.
    vp executive
    Nov 2007
    lakes entrance VIC
    my mate had his system stolen the even took the whole wiring kit right through to the battery! he laughed and said "dick heads why didnt they take the whole car the key's are still in the ignition" lmao
    but yes he had the amp screwed to the box
    [SIGPIC][/SIGPIC]
    rickshaw
    Jun 2006
    Quote Originally Posted by azzfox View Post
    Yes it does. When I had my sub and amp installed I asked the installer about this and he said that while it increases the risk of component failure, its not really something to worry about on a fairly basic setup and that in his 20 years of installing car audio equipment he has never had a single amp that had failed and he mounts them this way all of the time and if one had failed you can bet he would know about it with his lifetime install warranty. But yeah you are totally correct.
    rickshaw
    Jun 2006
    Quote Originally Posted by garfa View Post
    Mine would be so easy to steal, the amp is mounted to the sub and it is secured with two very visible clips. LOL oh well thats what insurance is for.
    Haydz's Avatar
    VS UTE LS1 T56
    Nov 2007
    or you could bolt it to the underside of the parcel shelf. or possibly mount it to the back of the rear seats.
    azzfox's Avatar
    VN SV3800 #012, N13
    Sep 2005
    Yarra Valley, VIC
    you can mount it to the underside of the parcel shelf, but I would suggest make a cradle of some sort so that the amp is mounted the right way up. otherwise it will render the cooling design useless because heat rises and the PCB will cop it making it prone to cracked solder joints and again components failing.
    yes im bored
    My (ex)Ride
  15. #15
    VRII Acclaim
    Jul 2005
    I cant see why. All components are solid state. A bad solder joint could be a reason, but on modern amps the soldering should be as good as that on computer parts.
  16. #16
    azzfox's Avatar
    VN SV3800 #012, N13
    Sep 2005
    Yarra Valley, VIC
    Quote Originally Posted by kopper69 View Post
    haha well.. my not so old PC motherboard failed not that long ago, still havnt found the exact problem but it died (have done numerous diagnosis so dont point the finger at human error). you cant guarantee everything to be perfect thats produced by a machine. theres always room for error. its just one of those risks i suppose (unless you have warranty )
    My (ex)Ride
  17. #17
    vs 96 acclaim
    Nov 2007
    yeah i mounted it to the back on my box but then after i did it pretty much realised it would be shaking the hell out of my amp...its a kicker 12 inch comp sub n it shakes the whole dam car haha....i was thinking maybe mount it the boot n mount it somewhere rear seat on the frame or something?
  18. #18
    Haydz's Avatar
    VS UTE LS1 T56
    Nov 2007
    still computers dont shake like subwoofers. they are mainly designed to spread the heat and not kill the computer. when you think. the sub is shaking whenever you have the radio on and if you turn it up a bit that could be pretty bad for the amp. like a boss or something but most good name brands should be able to take the beating it gets.
  19. #19
    wrx884's Avatar
    wrx884 is offline WA's ASR Rep
    VT Commodore Exec/5L VP Calais
    Mar 2006
    R u doin a custom boot fit out at all? or just utilising ur boot space how it is untouched? i think if its untouched mounting it 2 the rear seat would b the place 2 put it just make up some brackets if need b 2 help secure it properly. u could mount it under the parcel shelf as suggested but 4 a piece of mind thing i see that spot bein a spot that cops most of the heat in the boot from the out side so will b the 1st thing that heats up even tho heat shouldnt b an issue but like i said its a piece of mind thing n id rather keep my amps as cool as possible if i can.
    Check out my ride in progress.... 98 VT V6, V8 Supercar kitted
    Daily toy.... 92 VP Calais 5L
  20. #20
    azzfox's Avatar
    VN SV3800 #012, N13
    Sep 2005
    Yarra Valley, VIC
    all im saying is that electronics are fragile! treat them with care.
    My (ex)Ride
  21. #21
    VY SS
    Aug 2004
    SE Victoria
    more over why exert more external forces if you dont have to? regardless if an installer has not had an amp come back, do you want your amp to be the first???
  22. #22
    rickshaw
    Jun 2006
    Im guessing that was directed at me. No I don't want mine to be the first one to go back. The main reason that mine is mounted to the sub is that there wasn't really anywhere else to mount it because my car is on dual fuel, I couldn't mount it to the rear seat or underneath the parcel shelf. But at the end of the day the amp wasn't to expensive and I have already got a year and a half out of it, if I only got another 6 months before it dies I would be happy.
  23. #23
    VY SS
    Aug 2004
    SE Victoria
    nah not really, i could not even remember who posted it!
    more of a rhetorical question.
  24. #24
    Haydz's Avatar
    VS UTE LS1 T56
    Nov 2007
    i just spent some time in my boot and i couldnt for the life of me find a decent place to mount the amp. i still think the easiest and most practical solution is to screw it to the box.
    also would it matter if the ground cable were to become wet or damp. thanks.
  25. #25
    VY SS
    Aug 2004
    SE Victoria
    why would the ground come into contact with water?
