Results 1 to 13 of 13
Thread: Which 4 Channel Amplifier???
    VX Commodore
    Dec 2007
    WA
    Default Which 4 Channel Amplifier???
    Hi just need some help choosing an AMP, not sure what all the ratings mean to be honest not sure if I need to be looking at the 4 Ohms or 2 Ohms rating in order for the amp to be running my 4 speakers.
    They amps I have narrowed it down to are the following;
    MB Quart Premium PAB 4100
    MB Quart Premium PAB 4100 - 4-Channel Amplifier • MOSFET power supply • S/N Ratio: >95 dB • 24 dB subsonic filter - , Car Amplifiers, Multi-channel Amps - Sonic Electronix
    Product Description:
    * 4-Channel Amplifier
    * Focused mass aluminium heat sink
    * RMS Power Rating:
    o 4 ohms: 100 watts x 4 chan.
    o 2 ohms: 150 watts x 4 chan.
    o Bridged, 4 ohms: 300 watts x 2 chan.
    * MOSFET power supply
    * Ultra-flexible and variable adjustable active crossover network
    * Vario bass equalizer circuit up to +18 dB
    * 24 dB subsonic filter
    * Full range preamp outputs for easy daisy chaining of additional amplifiers
    * MB QUART-Logo with illuminated red rectangle
    * Wire concealing detachable end panels
    * Frequency Response (-3 dB) : 10 Hz - 30 kHz
    * Damping Factor: 200
    * Signal To Noise Ratio: >95 dB
    * THD: 0.05%
    * Channel Separation: >70 dB
    * Input Signal: 0.2 - 6.0 V
    * Crossover S/W: LP.BP/Full/HP
    * Variable Hi-pass / Subsonic Filter: 10 ~ 150 Hz
    * Variable Low-Pass (mono 24 dB): 30 ~ 150 Hz Full range
    * Bass Boost at 45 Hz: 1 ~ 9 dB
    * Dimensions: 18" L x 10.4" W x 2.25" H
    * 1-year Sonic Electronix warranty
    Amplifier Specifications:
    * Amplifier Class AB
    * Number of Channels 4
    * RMS Power (4 ohms) 100 watts x 4 channels
    * RMS Power (2 ohms) 150 watts x 4 channels
    * RMS Power (1 ohm) Not Stable
    * Bridged RMS Power 300 watts x 2 channels
    * Peak Power Output N/A
    * Minimum Impedance Unbridged 2 ohms
    * Minimum Impedance Bridged 4 ohms
    * THD at Rated RMS Power 0.05%
    * Speaker Level Inputs No
    * Preamp Outputs Yes - 1 pair
    * Built-in Crossover High-pass (HP), Low-pass (LP), Full (AP)
    * High-Pass Crossover Frequency 10 - 150 Hz
    * Low-Pass Crossover Frequency 30 - 150 Hz
    * Subsonic Filter N/A
    * Signal-to-Noise Ratio 95 dB
    * Channel Separation 70 dB
    * Bass Boost 0 - 9 dB
    * Bass/Gain Remote Yes
    * Fan Cooled No
    * Fuse Rating 50A x 2
    Now my other amp choice;
    Response Car Amp 4x100WRMS
    Jaycar Electronics
    Specifications:
    Power / channel @ 4ohm 14.4V: 130WRMS x 4
    Power / channel @ 2ohm 14.4V: 190WRMS x 4
    Power / bridged @ 4ohm 14.4V: 380WRMS x 2
    Signal/Noise ratio: >90dB
    Input sensitivity: 200mV to 5V
    Low pass filter: 50 - 500Hz @ 12dB/octave
    High pass filter: 50 - 500Hz @ 12dB/octave
    Pass thru RCA: Yes
    Dimensions: 400(L) x 258(W) x 50mm(D)
    Price doesnt matter, They Jaycar is $299 and the MB Quart AMP Retails for $999 but I can get it from that site for $380 AUD delivered
    I need them to power the following speakers;
    HERTZ HSK165
    HSK 165 - High-Energy - Hertz - audison
    Rockford Fosgate T1693C 6x9" 3-Way Coaxial Speakers
    Rockford Fosgate® - T1693C
    Configuration 3-Way Full-Range
    Midrange Diameter 6"x9"
    Midrange Depth 3"
    Tweeter Diameter .5"
    Tweeter Depth n/a
    Frequency Response 40Hz - 22kHz
    Power Handling 110 Watts RMS
    220 Watts Max
    Crossover High-Pass (HP): 12dB
    Sensitivity 90dB @ 1 watt/1 meter
    Grilles Included Yes
    Mounting Hardware Yes
    Shipping Weight 9.9 Lbs.
    (4.5 Kg.)
    I am going to be using a JVC KD-AVX11 Head unit with a CAT10 for the VX
    steering wheel controls.
    Well would appreciate everyones help and suggestion as I am looking at spending from 250-400 on a 4 channel AMP to power these speakers. And really like the MB Quart but not sure on how good there AMPS are.
    Thanks guys.
    anti
    azzfox's Avatar
    azzfox is offline slideways
    VN SV3800 #012, N13
    Sep 2005
    Yarra Valley, VIC
    Quote Originally Posted by antis0cial View Post
    the majority of car speakers are 4ohm. it usually will tell you on the back of the speaker. if not then you can use a multimeter (or a plain ohmmeter) to find out.
    im too lazy to look through it all so il give a basic run-down.
    *compare RMS or rated power (same thing) at same ohms as your speakers. disregard maximum power figures.
    *the amp should put out equal or more power per channel compared to your speakers.
    *its always best to overpower than underpower, you can adjust the 'gain' to avoid overpowering.
    My (ex)Ride
    Quote Originally Posted by ari666 View Post
    LMAO!!! bracelets!!! and neck chains?!?!? they are as gay as aids.
    Quote Originally Posted by Not_An_Abba_Fan View Post
    Nice 4 year old thread dig dude....got a permit to mine that deep?
    VX Commodore
    Dec 2007
    WA
    Hmmm alright? I think the Jaycar one is more powerful than the MB amp. So which would it be then? Out of the two amps I mean.
    azzfox's Avatar
    VN SV3800 #012, N13
    Sep 2005
    Yarra Valley, VIC
    ok I had a quick read anyway..
    Jaycar amp will put out 130wrms @ 4ohm per channel
    MB Quart will put out 100wrms @ 4ohm per channel
    the speakers are rated at 110wrms
    so yes the Jaycar amp is more powerful and wont underpower the speakers. but at 100wrms it would probably be too loud to listen to anyway so i wouldnt worry about underpowering with the MB Quart amp.
    My (ex)Ride
    VX Commodore
    Dec 2007
    WA
    Alright then cool. And i guess the JayCar I can get local aswell. So I am safe that way. Probably just stick with the JayCar like you said.
    Anyone else FOR or AGAINST?
    VY SS
    Aug 2004
    SE Victoria
    azzfox, shame on you mate, you know there is FAR more than just power figures.
    ok antisocial, the mb will be a far superior amp. it has less noise and probably better damping.
    really power means stuff all if we are looking at quality and the effect of power on a driver.
    i have not heard the mb amp, but i can say that i will sell you my jaycar 4 channel 4x130Wrms amp for $180 and i will pay the extra for the mb quart.
    sort of like chaulk and cheese really. or diamonds and dog ****.........
    azzfox's Avatar
    VN SV3800 #012, N13
    Sep 2005
    Yarra Valley, VIC
    Quote Originally Posted by garfa View Post
    ah come on, of course there is. but I just got the impression that the he/she was looking for something to power his/her speakers without going into much detail. if not well then sorry. thats when other people come in and have their say. plus.. I never recommended anything! I just stated the facts!
    alright, bed time.. im getting grumpy
    My (ex)Ride
    VX Commodore
    Dec 2007
    WA
    Thanks Garfa, So it wouldnt matter if the MB Quart is only 100w RMS and my speakers I think are 110w rms and 130w rms. I mean it wont stuff em up or anything if the MB is running em at 100w only. I just thought the Jaycar because its local the MB is 380 AUD delivered from the states rather than the 999 price tag these prix sell it in perth for. Or is there any other amp in the 250-400 price bracket someone would recommend? or is the MB basically best buy for me at the moment? Id rather have quality than just plain loud noise to be honest coz I probably wouldnt crank it past 10-15 anyways. I was just told if I get an up that is less RMS than my speakers I would stuff em up.
    Sh&t this is confusing, shoulda just stuck with factory.. lol
    VY SS
    Aug 2004
    SE Victoria
    Quote Originally Posted by azzfox View Post
    i just thought i would give you a stir because you are good for it!
    ANTI: mate there is no real world difference for us between 100 and 130 Watts, only whats on paper.
    the MB will be a go'er. just make sure its from a good source, dont want a fake now.
    azzfox's Avatar
    VN SV3800 #012, N13
    Sep 2005
    Yarra Valley, VIC
    hmmm ok... lol
    yeah your probably right. I think I have a problem of always looking at the technical side of things those power figures might not even be 100% accurate anyway give or take.
    My (ex)Ride
    VX Commodore
    Dec 2007
    WA
    Thanks guys, might just got for the JayCar one now, due to budget restrictions cause of christmas shopping. And also abit hesitant since the MB is from the USA, I mean I would save bout 600 AUD off the Ozzie retail price. But that doesnt matter if I was to receive a fake. But for now, JayCar 4 x100 it is. time to look for a second hand one hopefully, as cant be bothered getting a new one since I only plan to have it for a couple months.
    Thanks guys and Merry Christmas
    VN HSV WAGON
    Jan 2008
    Mate if you havent already bought one I am running the jaycar one you mentioned and value for money and performance wise it rate it very highly. I erun 2 x 12" subs off it and 2 X (6x9's) and I'm seeing 120+dB in a VN wagon. The AMP also controls the SUBs very well with a very clean tight sound.
    I say GO FOR IT
    VY6 Ute
    Jan 2008
    Aspendale, VIC
    as everyone else has said mate, the jaycar amps are fantastic for what you pay for them, im using one of their response 4x100w and a 1000wrms monoblock with 4 Alpine Type R speakers and 2 Pioneer slimline 12" 's and ive got no grievances whatsoever.
  1. Fan Amplifier VS
    By Kevin in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-06-2010, 04:39 PM
  2. mounting an amplifier
    By Brycestro in forum Car Audio
    Last Post: 10-03-2006, 12:49 PM
  3. statesman amplifier????
    By lilkel in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-01-2006, 11:59 PM
  4. 3rd Amplifier for my system
    By ashtray1 in forum Car Audio
    Last Post: 17-12-2005, 12:24 PM
  5. Audiobank Mofset 2x Channel 200 Watt Power Amplifier
    By markc3012 in forum Parts And Other Items For Sale
    Last Post: 04-05-2005, 11:04 AM
