I just put 300w 6x9's in my parcel shelf, and i have a few questions about the wiring.
-Is the standard wiring fine to use or will i get better sound quality by replacing it?
-The new speakers have different metal clip/connector things than the standard speakers, will auto barn etc just sell a pack of ceonnetors that are right for my speakers? and will these be fine if i need to extend the wiring a little ?
thanks for any hyelp, it's my first time doing anything like this.
cheers
you can just wire the speakers if you strip the cable back and inch or so. then wrap is back over itself. if it doesnt move it will be ok. you can just get some ruber insulators ifu wana be on the safe side
you can use the standard wiring. if you amplifiing the speakers it might be an idea but not necessary
yer, the standard wiring should be fine but if you amplify the speakers you should go something a little heavier gauge. i like to run my own heavier wiring whichever the case. any car audio shop should sell the female connections you need.
the standard wire is fine for speakers.
dont bother replacing it.
cheers for that
