Results 1 to 24 of 24
Thread: Splits into a vs
    VT S Pack
    Dec 2007
    Goldcoast
    Default Splits into a vs
    i was just wondering guys, and dont flame me if i didnt allready see a thread ont eh same sorta subject.
    my question is, how hard is it to put a pair of splits into the stock position of a vs commodore, the tweeters up near teh windshield and the woofers down the bottom? how hard is it and will i have to cut stuff etc?
    VT S PACK
    VY6 Ute
    Jan 2008
    Aspendale, VIC
    mate its allllll too easy, if you stick with 6" splits you shouldnt have to cut a thing. could probarbly even push a 6 1/2" (may have to cut a little bit off the edge), theres plenty of guides on the forum if you get stuck anywhere, but once you remove speaker covers etc. its as simple as disconnecting, reconnecting and remounting the new speakers!
    VT S Pack
    Dec 2007
    Goldcoast
    Quote Originally Posted by LJS-UTE View Post
    evan thetweeters?
    VT S PACK
    VY SS
    Aug 2004
    SE Victoria
    mate we dont know how good you are with your hands.
    most people will say its easy, the only way is to try.
    VT S Pack
    Dec 2007
    Goldcoast
    Quote Originally Posted by garfa View Post
    eh im allright i just hate pulling the dash off lol
    VT S PACK
    vs calais eco
    Sep 2006
    Disney land!
    just dont pull the steel mesh grill of the front of the door pods as you cannot get to the speaker this way! you have to remove the door trim its self!
    VT S Pack
    Dec 2007
    Goldcoast
    Quote Originally Posted by cxcxcxvcvcvc View Post
    i noticed this after alot of prying LOL who designed it that way? -.-i hatre takeing door trim off lol
    VT S PACK
    vs calais eco
    Sep 2006
    Disney land!
    Quote Originally Posted by mattgreen View Post
    haha i know how you feel mate! thats why i tried to warn you first now for your tweeters in the dash, there is a small screw in the vents you will have to get out with a small stubby philips screw driver, after that the actual vent that covers the tweeters should pull out to reveal the factory tweeter!
    VT S Pack
    Dec 2007
    Goldcoast
    oh so you dont take the dash off ? , yess i left a little mark on one of my pods fromt eh prying lol cant see it tho =]
    VT S PACK
    vs calais eco
    Sep 2006
    Disney land!
    no dont take the dash off, the 2 ac vents that sit up on the dash come out after you remove the small screw (there could be 2 screws cant rember lol) but once you remove the screws the actual ac vents that runs along the front of the windscreen should come out
    VT S Pack
    Dec 2007
    Goldcoast
    oh true, another question.
    where does the wire to them tweeters go to? LOL cause id have to take the dash off to re run wires for splits through wouldnt i?
    VT S PACK
    vs calais eco
    Sep 2006
    Disney land!
    No, what you do is after removing the tweeter screws, cut the factory tweeter wire and then with your new tweeter wire feed it down the hole where the original tweeter wire runs, you then drop down the panel under the steering wheel and you should see your new tweeter wire in there somewhere, and from there you can hook up your splitter box and stash it under there aswell on the other side however you will have to remove the glove box and when feeding your new tweeter wire down the hole just look for it in the space behind the glovebox! if you have enough tweeter wire you can run the passenger tweeter splitter box and put it under the drop down panel with the other splitter box i have to go out now to bob janes to get a tyre repaired but should be back in a couple of hours, so best of luck with it mate
    VT S Pack
    Dec 2007
    Goldcoast
    ok mate thanks, well the glovebox is no issure seeming when i open it it falls out haha, i gota fix it but i have no idea how, the right slip the holds it in snapped off? what should i do lol and eyahh thanks for that i dont think it would be to much trouble to install the speakers .
    another thought is instead of re running new speakers through the gromit in the door i could use the existing wire then jsut cut it off when it gets to the inside of the car, run that under the trim to the boot and amp it? or should i run whole enw wire the whole way?
    VT S PACK
    VY SS
    Aug 2004
    SE Victoria
    you can use the old wire no probs.
  15. #15
    VT S Pack
    Dec 2007
    Goldcoast
    so evan with the higher power from the amp it wotn matter?
    VT S PACK
  16. #16
    VY SS
    Aug 2004
    SE Victoria
  17. #17
    OZ-18-OI is offline OZ-18-OI
    1995 VS Exec 5 Speed & 1996 VS Commo Acclaim
    Dec 2007
    hey mate, ive got a pair of 6inch splits in my vs, got the woofer in the right spot, got the cross-over in the door pod (sideways) and got the tweeter in the door just about the air vents on that flat bit, mine arent flush mounted..
  18. #18
    VT S Pack
    Dec 2007
    Goldcoast
    Quote Originally Posted by OZ-18-OI View Post
    hey mate could u post a pic of the tweeters thanks =]
    VT S PACK
  19. #19
    VS Exec Wagon
    Jul 2006
    Far Sth Coast Of NSW
    dont make the mistake of gettin 6.5inch otherwise a easy job becomes a long and painful journey!!! as i found out.... once the splits are in you will love it
    Holden VS Commdore Wagon, No1 Cruising Machine!!! On The Hunt For A New Beast...Its Time 4 Me 2 Get Uted!!!!
  20. #20
    Dec 2007
    here you are mate, just put a little hole in for the speaker wire...no dramas, goes hard
  21. #21
    VT S Pack
    Dec 2007
    Goldcoast
    oz were your splits 6.5 inch or 6? 6 1/2 fit fine in the back in the stock positions
    VT S PACK
  22. #22
    VY SS
    Aug 2004
    SE Victoria
    it depends on the speaker.
    just because some 6 1/2 inch fit does not mean all will.
  23. #23
    Dec 2007
    my speakers were 6 and ½ inch, they went into the stock personition perfectl...with ease haha and now happier then ever, then work and they pump... just got to find some double sided tape that actually holds haha
  24. #24
    VT S Pack
    Dec 2007
    Goldcoast
    double sided tape for what? :P
    VT S PACK
  1. need ur help with splits
    By jvys in forum VY Holden Commodore (2002 - 2004)
    Last Post: 19-06-2006, 07:48 AM
  2. What amp for splits??
    By kmbattle in forum Car Audio
    Last Post: 15-02-2006, 01:42 AM
  3. where to put splits in a vk.
    By 84_vk_wgn in forum Car Audio
    Last Post: 05-01-2006, 09:33 PM
  4. 3 way splits
    By bensta in forum Car Audio
    Last Post: 25-12-2005, 10:30 PM
  5. splits
    By VL-187 in forum Car Audio
    Last Post: 06-12-2005, 08:28 PM
