amp wiring question
fredothefrog
VL 5.0
wats the best way or place to get the positive wire through the firewall on a vp commy cheers
roon_VR
VR executive Commodore
www.myspace.com
3.8 V6 executive SII VR
i dont know about the VP, but on a VR, there's a rubber grommet behind the brake booster. You can easily fit it through there and out through the other side where the fuses are.
jet_pilot
lakes entrance VIC
vp executive
i run mine through near the steering colum
fredothefrog
VL 5.0
okay sweet is it hard to get to that rubber grommet from under the dash thanks for ur advice
roon_VR
www.myspace.com
its a bit tricky if you only feed the power cable through the grommet to the dash. A good idea is to use a straightened coat hanger and tape it to the power cable and then poke it through the grommet. It should be clearly visible under the dash.
jet_pilot
lakes entrance VIC
vp executive
i dont have a grommet where the steering colum is i just poked it through
Joe Peeps
VS Acclaim
The grommet is there for a reason where cables are put through metal... Get some rubbing and youve got a short in your power cable... Short in 12v line = not good :(
roon_VR
www.myspace.com
Isn't it also illegal to put new holes in the firewall?
jet_pilot
lakes entrance VIC
vp executive
its not where the wires go through its where the steering colum goes through they dont have a grommet for that theres insulation tho and ive got conduit over the wire
garfa
37
SE Victoria
VY SS
but not too bad because all people should have their feed fused appropriately!
