Had my kenwood 250watt 2 channel out of the car for about a month, put it back in today and when i wired it up i have power going in but not coming out have been trying to fix it for about an hour now and its raining and i am wet from running in and out of the car, Does anyone have any Ideas on what the problem maybe????
I am thinking something internal is goooone.
but not to sure.
cheers
is it lighting up? does the rca cable make sound when connected to another amp? is there power at the cable that you have tested with a multimeter? are all connections on the power and ground tight?
if the rca and power and ground are fine then its time to send the amp to be looked at.
yer the light on the amp is on that is fine and that rca's did work when i had this am,p running a sub, on the back of the head unit I have 3 out puts sub woofer,front and rear I have now got these rcas in the front out put could it be that nothing is getting from the head unit to the amp just been thinking about it all day. any ideas of things i could try
Problem soved yay for me!!!!!!!!!
flicked the amp from mono to stereo couldn't see this swithc in the dark last night, this gave me only my tweeters as a dipstick mate used the wrong cable to wire to woofers but after pulling my dash apart to get to the joins all is good.
