Results 1 to 12 of 12
Thread: Hot weather = wiring problems?
    glassjowned is offline "Banana Hammock"
    VXII Exec.
    Mar 2006
    Country SA.
    Default Hot weather = wiring problems?
    My speakers have stopped working, head unit is reading cd's just no sound. I'm assuming this is caused by the recent heat we've had.
    If so, is there anything obvious that can be the exact problem? I mean something I should check first before re-wiring the entire thing?
    Grow up. Everyone. Just grow up. Now.
    wrx884's Avatar
    wrx884 is offline WA's ASR Rep
    VT Commodore Exec/5L VP Calais
    Mar 2006
    Is this from an after market unit or orginal? any amps/subs installed? lil more info needed so we can help ya out man.
    Check out my ride in progress.... 98 VT V6, V8 Supercar kitted
    Daily toy.... 92 VP Calais 5L
    VXII Exec.
    Mar 2006
    Country SA.
    oh yeah its an aftermarket head unit with aftermarket speakers front and rear running off of it
    forgot to mention there is a short crackly kind of noise from one of the rear speakers when first turned on but as I say none of them are working.
    VY SS
    Aug 2004
    SE Victoria
    does the radio work?
    reset the h/u to factory settings.
    if still not working then remove and send off for repair.
    VXII Exec.
    Mar 2006
    Country SA.
    so you think its the head unit? i thought it must have been just the wiring? guess i could try putting another one in there.
    too damn hot though ha
    VY SS
    Aug 2004
    SE Victoria
    well mate if they were working, now not and you havent changed anything, the h/u comes on its probably a h/u problem, unlikely all speakers would be stuffed at the same time.
    Tasmaniak's Avatar
    Tasmaniak is offline Not a valid input....
    car
    Apr 2005
    speaker wire shorting out somewhere will often shut the system down to save itself....or **** itself.
    VXII Exec.
    Mar 2006
    Country SA.
    thats what i thought might have happened
    VY SS
    Aug 2004
    SE Victoria
    VXII Exec.
    Mar 2006
    Country SA.
    Quote Originally Posted by garfa View Post
    assumed there was no amp?
    there is no amp.
    wrx884's Avatar
    Mar 2006
    Did u just use the original speaker wiring? eg. from all 4 doors? check ur wiring at the back of the unit, check the wiring is still attached 2 ur speakers aswell and make sure nothing has come appart, if all seems good id say garfa is right. can u get ur hand on a spare head unit 2 do some tests?
    VXII Exec.
    Mar 2006
    Country SA.
    I've had everything except the cd player installed by Autobarn. I do have a spare player I can check with. Will do this asap.
  1. Wiring Problems!!!
    By Kall911 in forum Car Audio
    Last Post: 13-10-2006, 07:14 PM
  2. wiring problems????
    By lilkel in forum Car Audio
    Last Post: 24-09-2006, 08:19 PM
  3. problems with stereo wiring
    By vy_pete05 in forum Electrical Wiring / Questions
    Last Post: 29-05-2006, 09:12 AM
  4. VT wiring, above fuel tank causing problems
    By Ian J in forum Electrical Wiring / Questions
    Last Post: 30-10-2005, 10:04 AM
  5. VS radio wiring problems
    By tgolds1 in forum Electrical Wiring / Questions
    Last Post: 24-05-2005, 06:13 PM
