Hi, just mounted an amp in my boot, and was just wondering which sides of the car I should run my wiring (ie. power and speakers). Is it alright to run speaker wire past the car's computer (left side)? or will this cause interference? What's everyone else done?
ive always ran he positive power wire on the same side of the battery. and the RCA's on the opposite side.
can run the rca down the trans tunnel if you want as well.
speaker wire and ecu are fine, you can even run it next to the power for a bit if need be.
in my vr, the rca is on passenger side, power, remote, and 6 x 9 speaker cable on driver side. This seems logical, although there is a on/off missile switch connected to the remote line to turn the amp on and off, although this was a hassle it is worthwhile if ur deck doesnt have sub control.
like i said not ideal, but if you *have* to...... (eg if your too slack!)
is that a pain in the arse through the trans tunnel. or did you just lift up your carpet. and run it underneath. just not sure how i should do it? thanks alot
even though this aint my thread.
correct me if im wrong, but speaker wire should be fine to run with power wires. it is only signal wires (RCA's) that you should worry about. interference (buzzing noise) is caused by the electrical field of power wires penetrating poorly shielded RCA's which is then amplified and sent to your speakers.
As azzfox said, its only line level (your RCAs) that you have to worry about getting interference and humming. Speaker level (post-amp) is not affected by this - unless it is running alongside high voltage power cable, which you simply dont find in cars.
use a coat hanger unbent. the wire is stiff and you can just tie of the rca's or what ever. better than trying to get your arm under there.
