I recently upgraded the speakers in the doors but when i enquired about the subs was told they dont make 8" free to airs and to replace with a good set of 6X9 or 7x10s. I purchased the 6x9 MTX puppies and installed them easily enough but stupid me they only pump out bass and low amounts, sounds worse than the subs.
Do i need to bypass the amp by using one of phreddys contraptions and therefore require an amp?
By the way where is the amp?
If you want more inches, STROKE IT!
the amp is on the passenger side of the car in the boot
to get access to it you need to remove the carpet on the side wall and then you should see 4 screws, losen them and you can get the amp out, you can only adjust the gain on the standard amp heres a pic of what it should look like when you take the carpet off the side and the 4 screws.
By the sounds of it the sensitivity on the 6x9's isnt as high as the subs where, so u will need to up the gains on the stock amp..
RUN41T: Real cars don't power the front wheels... they lift them
the factory amp is set to low pass thats why you should have gone with new 8 inch subs and yes they make them many diferent brands
youll always only get bass out fo ya 6x9s unless you replace the amp
sell ya 6x9's cover holes get real sub instead
much bassier
Bucket - I have a feeling that the original subs which came out of there are 2 ohm impedance (someone correct me if I'm wrong though...), whereas I'm pretty certain that your new MTX units will be 4 ohm. What this means is that for the same voltage at the speaker terminals, you're only able to push half the current as wil a 2 ohm load - half the current means half the power.
You might be able to increase the gain level of your sub amp, there are several articles on how to do that.
(then again, I might be barking firmly up the wrong tree too!)
Good luck with it, cheerz.
New look ASR Website online now!!
www.asr-audio.com.au
Interior lighting and audio specialties
for VT/VX & VY/VZ Commodore / Monaro
NOW VE DASH LIGHTING CONVERSIONS!!
PLUS TECH2 DIAGNOSTIC SERVICES
JBL Car Audio dealer
hey , wat size speakers are in the doors , wat did you replace them with ? was it a hard job? does it sound much better , and who makes good 8" subs
