Results 1 to 12 of 12
Thread: easier way?
    Haydz's Avatar
    Haydz is offline 346 cu/in
    VS UTE LS1 T56
    Nov 2007
    Liverpool.Sydney,NSW
    Default easier way?
    hey guys. im just doing the wiring for my front speakers and trying to get the wire through the rubber grommet that connects all the electrics to the door yeah. and i cant get it through anyone found an easier way to do it?
    thanks alot
    RUN41T's Avatar
    RUN41T is offline Go forth and modify
    Vy SS
    Jun 2006
    Wollongong
    I did it useing a piece of straightened coat hanger taped to the cable and i smeared washing up liquid over the cable, Slid straight in
    RUN41T: Real cars don't power the front wheels... they lift them
    VY SS
    Aug 2004
    SE Victoria
    Haydz's Avatar
    VS UTE LS1 T56
    Nov 2007
    Phreddy's Avatar
    Phreddy is offline Bye SV6 - still love you
    VS-II Statey-8
    Apr 2005
    W-Sydney NSW
    I'm not sure about your VR, but in both my VT and VZ I was able to "unclip" the plastic body at each end of the rubber "tube" from the door and the pillar. Once that's done it's a whole lot easier to get the wire through - then clip the plastic body back in. Voila!
    (BTW - if it was me I wouldn't just run the cable beside the rubber cover - for both appearance and reliability's sake. I've seen a shorted speaker wire nearly set fire to a car - running under upholstery, getting hotter and hotter as bags of current flowed in it. Scorched the upholstery foam, and nearly had it catching fire before the amp fried) That's just my preference though....
    Cheerz!
    New look ASR Website online now!!
    www.asr-audio.com.au
    Interior lighting and audio specialties
    for VT/VX & VY/VZ Commodore / Monaro
    NOW VE DASH LIGHTING CONVERSIONS!!
    PLUS TECH2 DIAGNOSTIC SERVICES
    JBL Car Audio dealer
    wrx884's Avatar
    wrx884 is offline WA's ASR Rep
    VT Commodore Exec/5L VP Calais
    Mar 2006
    i just did wat Greg said a few weeks ago in the VP so id say the VR's would b the same it was easier 2 take the door skin off and push that grommet 1 through with ur fingers, the other grommet on the pillar u can pull out after wen u have something 2 grab onto then.
    Check out my ride in progress.... 98 VT V6, V8 Supercar kitted
    Daily toy.... 92 VP Calais 5L
    Torquative's Avatar
    Torquative is offline go in Luxury
    Grandpa Spec WK Statey
    Jun 2005
    I just payed an electricion (dad) 3 beers first then asked him to do it lmao
    Acctually he was more then happy to show me how to do it properly with the conduit, then after the first door and another coldie and a chat with my mates, he then continued to do a second one, then the 3rd, but we decided we wanted a go!
    Plastic conduit worked the best because it didnt peirce the rubber like I did in my VX when i used wire, but it can be a pain to do
    commsirac is offline Banned
    vx
    Aug 2007
    Quote Originally Posted by Haydz View Post
    thanks alot
    If its dual flex cable, separate the flex and do them one at a time........may or may not work!
    VR manual
    Jan 2008
    theres no need to put the wires trhough the grommet, just use the cable that is already there and wire it up to your new stuff, i think the right side is two green wires and the left side is 2 brown ones
    roon_VR's Avatar
    roon_VR is offline VR executive Commodore
    3.8 V6 executive SII VR
    Mar 2007
    Quote Originally Posted by manual_vr View Post
    yeah, what manual_vr said. For the left hand side, you can take off the glove box and you can access the two wires for the left speakers. From memory i think they are brown and white wires. You'll be able to know because of the factory plug-in style connectors for the speakers.
    On the other side, there's a light green speaker wire and a dark green speaker wire. to access that, all you have to do is screw off the plastic bit at the end on the drivers side. Pull that off gently and you'll be able to access those speaker wires.
    From what I've done, it's much easier than feeding speaker wire through the grommet into the doors.
    hope that helps.
    My car audio:
    CD tuner: Alpine CDA-9884E with Ipod interface
    Front speakers: Alpine Type R SPR-17S 6.5 component speakers, powered by a avant-garde 23dxi 2 channel amplifier - 2x51 watt RMS
    Rear speakers: pioneer coaxials connected to tuner
    Subwoofer: Alpine Type R SWR-1222D 12" 2 ohm dual voice coil 500 watts RMS powered by a response precision 2x150 watts RMS 2 channel amp bridged to 500 watts RMS @ 4 ohms
    Haydz's Avatar
    VS UTE LS1 T56
    Nov 2007
    but then if you ever want to revert to the headunit for sound. you have cut the wires. and there would be too much fiddling. i put my own through and run them to the amp. sounds good
    roon_VR's Avatar
    Mar 2007
    im glad it sounds good
    My car audio:
  1. modifying my dash, what do you think will be easier..?
    By fluxxx in forum VY Holden Commodore (2002 - 2004)
    Last Post: 18-08-2009, 09:41 AM
  2. swap starter or whole motor - what is easier
    By vh-holden in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 11-10-2007, 09:49 PM
