Results 1 to 6 of 6
Thread: amp not turning off
    Burnout_bro's Avatar
    Burnout_bro is offline Donating Member
    HYPER VX SS/ R33 GTST
    Dec 2006
    Default amp not turning off
    i just installed my kicker mono block but it doesnt seem to turn off when the car is off, green light stays on, and my battery is now dead because of it, i previously had just the 4 channel running so i used a dist block and hooked up the mono aswell, never had any problems so i know the wiring is fine.
    commsirac is offline Banned
    vx
    Aug 2007
    Perhaps it would be useful to describe how you have the amp wired?
    Does the amp just have a live feed or is it triggered by a 12V source, and if so what is it triggered by?
    If it is triggered by the radio it would be useful to check that the 12V trigger wire is dropping away to zero when you turn the radio off, or indeed seeing that the amp switches off when you remove the trigger wire. If it doesnt turn off when you remove the trigger wire the problem is in the relay in the amp, if it does, the problem is in the HU.
    If its the amp relay, then possibly a cheaper alternative just to supply it with a normal 12V automotive(with suitable current rating) using the same trigger as before rather than get the amp repaired
    RUN41T's Avatar
    RUN41T is offline Go forth and modify
    Vy SS
    Jun 2006
    Wollongong
    A ,ate of mine had this problem with another amp, he had rewired it and 1 strand of the power cable was touching the remote input, it was enough to make the amp stay on.
    Check your remote wire, if it is fine i cant see any reason for the amp staying on. Maybe a faulty amp?
    RUN41T: Real cars don't power the front wheels... they lift them
    dd08 is offline Dicky D
    95 vr series 2 acclaim/ 97 vr series 2 acclaim
    Aug 2008
    melb
    have you wired the amp remote wire or amp rem as the manuals call it from the amp too the headunit if that isnt plugged in in most cases you will still run power even known the car is shut off as your amp wire is directly hooked too the battery and the ground is on the body.
    Sep 2007
    vlv8vic's Avatar
    vlv8vic is offline <---Brad Quaid = internet stalker
    M5
    Mar 2005
    Australia
    had the same problem when i first put mine in. while it was a long time ago i believe it was something to do with the remote wire.
  1. vh not turning over??????
    By NOT.BT1 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 08-04-2007, 07:11 PM
  2. Clunking when turning...
    By VNCalais98K in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 14-01-2007, 11:57 PM
  3. heater not turning to hot
    By auprincess2001 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-05-2006, 03:07 PM
  4. Car not turning over properly
    By andrewmac in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-03-2006, 06:00 PM
  5. delay after turning key...
    By g00gz in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-03-2006, 01:00 AM
