Results 1 to 5 of 5
Thread: head unit and sub
    Nov 2004
    Default head unit and sub
    I have a pioneer h/u which is able to power a sub, just wondering how well the h/u can handle a sub is it worth doing.
    Julie's Avatar
    Julie is offline moderator- for now anyway
    Blown VT Calais 355 + SC VY V6
    Mar 2004
    Western Sydney, NSW
    Theres not much point running a sub straight off the headunit, you will need to get an amp to give the sub decent power and decent results.
    Blown VS Calais !!
    Jan 2005
    Kalgoorlie WA
    If your on a budget then get a samll 10 , probably an 8 , and make sure it is a single 4 ohm coil , using the rear channels bridged it will get about 70-80 watts rms.
    But always better with an amp.
    Right click save as . .
    May 2004
    Lake Macquarie NSW
    You may want to read the specs a bit closer, usually if a h/u has a output feed for a sub its only a pre-amp line designed to feed an amp.
    GT
    Jesus.........please protect me from your followers!
    Blown VS Calais !!
    Jan 2005
    Kalgoorlie WA
    You may want to do your own research squizzy , as the Pioneer decks with MOSFET can indeed and are rated to be bridgeable on the rear channels.
  1. VZ head unit
    By VZ219 in forum Car Audio
    Last Post: 12-02-2007, 05:40 PM
  2. Which head unit?
    By Famine in forum Car Audio
    Last Post: 02-10-2005, 05:02 PM
  3. VR Head unit
    By Nikkojoe in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-01-2005, 10:44 PM
  4. Can't Get Head Unit Out
    By sk1p in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-01-2005, 06:33 PM
