Results 1 to 9 of 9
Thread: power antenna and aftermarket stereo
    vy calais sv6
    Jan 2008
    Default power antenna and aftermarket stereo
    hey guys,
    im looking at getting an alpine cda-9886 for my vy calais by it seems that the alpine only has one wire for the power aerial, where as the commodore has two wires, one for up and one for down... am i missing something here? how are you guys able to make sure aerial's still work with aftermarket stereos?
    cheers
    azkwazere is offline Ahhh Yes, Ahhh Yes....
    VP 5-SPD / 24-SPD Racer Hybrid
    May 2005
    .....SE Burbs
    The wire from your head unit is +12V, when it activates, usually the antenna goes up and satys up... when the power is lost(wire deactivates) the areal drops. IMguessing the Vy ones work in that id you supply power, or earth, to the up wire, it goes up, same with the down wire... Earth out the Antenna Up(on antenna) wire while its down and see what happens... if nothing, supplly 12v to it... have a play.
    you may ahev to make a custom stwich/relay for it...
    aZk.
    Wanted to buy:
    1. T5 V8 Bellhousing and Clutch fork assembly suit VP
    2. V8 Tail Shaft, T5, Suit IRS VP
    3. T5 VB Gear Box
    PM Me if you got what i need...
    Quote Originally Posted by ryno_vrx View Post
    honestly i doubt it will happen cause kanye west will just interrupt Armageddon anyways
    vy calais sv6
    Jan 2008
    ok cheers for that aZk...
    anyone know for sure how its done before i try...?
    | evaN |'s Avatar
    | evaN | is offline mmm bass
    VT
    May 2006
    SE Melbourne
    VN - VZ
    Accesories - Yellow
    Constant - Orange/White
    Illumination - Brown/White
    Earth - Black/White
    12V OUTPUT - Yellow/Red
    Radio Mute - Yellow/Black (VT onwards)
    Antenna up - White (VR onwards)
    Antenna down - Blue (VR onwards)
    Illumination OUTPUT - Grey (VT onwards)
    according to that aZk is right. it shouldn't be that hard to wire it up with a relay.
    buy a 12v relay like this one from jaycar
    and connect it like the pic attached below if the antennas work off 12v. if not replace 12v with GND.
    Attached Thumbnails Attached Thumbnails power antenna and aftermarket stereo-relay.jpg
    2003 VY S1 Commodore Berlina sedan
    Oct 2005
    Wellington, New Zealand (Yes i know yet another KIWI)
    the other thing is that your factory head unit may have had antenna hight adjustment so the extra wire could be linked in with the hight adjustment.
    vy calais sv6
    Jan 2008
    vy calais sv6
    Jan 2008
    i just got a reply from alverts car stereo with the same question, they replied:
    Just connect the yellow/red wire to the blue wire and the antenna will work the same way.
    is this correct?
    Series II VE SV6
    Feb 2008
    Quote Originally Posted by | evaN | View Post
    VN - VZ
    Accesories - Yellow
    Earth - Black/White
    Anyone tried this?
    I don't know much about this stuff so can some clear something up for me.
    Can i run a wire off the 12v wire that goes to the head deck to the relay and same for the ground wire?
    1994 VR 5 Litre Caprice
    Jul 2009
    Liverpool
    VN - VZ
    Accesories - Yellow
    Earth - Black/White
    So which wire would be to keep the memory on the aftermarket ? The constant wire?
  1. Replies: 5
    Last Post: 31-12-2007, 06:44 PM
  2. wiring a Aftermarket power antenna to the factory switches
    By 12000 in forum Electrical Wiring / Questions
    Last Post: 24-03-2007, 08:55 AM
  3. VY Power Antenna & AfterMarket Head Unit
    By Exceler8r in forum VY Holden Commodore (2002 - 2004)
    Last Post: 26-08-2006, 12:59 AM
  4. VZ Antenna with Aftermarket HU
    By kilmo in forum Car Audio
    Last Post: 15-03-2006, 09:52 PM
  5. aftermarket electric antenna
    By vs_family_wagon in forum General
    Last Post: 09-02-2005, 09:31 PM
