Results 1 to 9 of 9
Thread: amp wiring issues
    RIC_VP's Avatar
    RIC_VP is offline [HEKT1K]
    VP Executive
    Sep 2007
    Default amp wiring issues
    hey all,
    i've just wired up a dual sub set up (2 x clarion subs, 300w RMS each) together with a soundstorm 4ch amp (which i believe is 4 x 110w RMS).
    i have connected the positive wires and the negative wires from each sub together, and put them into the positive side of ch1 and the negative side of ch2.
    does this mean i am not using all of the amp's available power? because it doesn't sound as good as 600w RMS total probably should IMHO.
    i am fairly new to car audio, just wondering if anyone can give any advice as to how i should be wiring everything up.
    cheers
    roon_VR's Avatar
    roon_VR is offline VR executive Commodore
    3.8 V6 executive SII VR
    Mar 2007
    Quote Originally Posted by RIC_VP View Post
    hey all,
    cheers
    No you're not using the amps full power. you've still left channels 3 and 4. What i suggest you do is connect the first sub's positive to channel 1 positive and the first sub's negative to channel 2 negative. likewise to the second sub to channels 3 and 4.
    It should sound much better after doing that.
    good luck,
    My car audio:
    CD tuner: Alpine CDA-9884E with Ipod interface
    Front speakers: Alpine Type R SPR-17S 6.5 component speakers, powered by a avant-garde 23dxi 2 channel amplifier - 2x51 watt RMS
    Rear speakers: pioneer coaxials connected to tuner
    Subwoofer: Alpine Type R SWR-1222D 12" 2 ohm dual voice coil 500 watts RMS powered by a response precision 2x150 watts RMS 2 channel amp bridged to 500 watts RMS @ 4 ohms
    RIC_VP's Avatar
    VP Executive
    Sep 2007
    awesome thanks for your help mate..
    i was just separating the wires now and i realised that i only have 1 set of rca plugs, which are plugged into the ch1/ch2 slots on the amp.. i assume this is a problem because after putting each sub into ch1/ch2 and ch3/ch4 there was no sound coming from them. is it now a matter of getting more rca plugs?
    Cobez's Avatar
    Cobez is offline LS-EXUAL
    2004 S2 VY SS Ute
    Feb 2007
    Sure is mate. Grab some of the sony ones from JB. 4 heads on each end. I got the longest ones which were 10 metres. Left myself alot of slack on the cable incase i wanted to move amps around or something.
    Quote Originally Posted by wikky
    As already stated, mate you're an absolute gherkin strummer.
    roon_VR's Avatar
    Mar 2007
    Quote Originally Posted by Cobez View Post
    no you don't need new RCA's. You can still run 2 sub woofers with 2 RCA plugs. put one RCA into (white or red) left, and the other in the (white or red) right.
    My car audio:
    RIC_VP's Avatar
    VP Executive
    Sep 2007
    ok sweet.. ill try the cheaper/easier option first and see how i go.
    JC to the rescue once again! thanks guys
    Ric
    roon_VR's Avatar
    Mar 2007
    im glad to help
    My car audio:
    Cobez's Avatar
    2004 S2 VY SS Ute
    Feb 2007
    Quote Originally Posted by roon_VR View Post
    Depends, i am running 2 amps, i have a 4RCA output, i run 2 sets to my split and rear speaker amp, two plugs on each end. So that's 4 plugs all up. One set into the FRONT LEFT / RIGHT in the head unit to the amp, the other set REAR LEFT / RIGHT into the amp. Then i linked the 2 amps together.
    roon_VR's Avatar
    Mar 2007
    but he is only using the one 4 channel amp, so another set of RCA plugs are unnecessary and besides, he is only running 2 speakers (2 subwoofers) off the amplifier and not 4 speakers like you are for your front left/right and rear left/right.
    My car audio:
  1. sub wiring issues
    By white vn ss in forum Car Audio
    Last Post: 12-11-2006, 02:04 PM
  2. VH SL Wiring And Other Issues.
    By Portunio in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 17-02-2006, 01:57 PM
  3. Converting standard fog light wiring to driving light wiring
    By tungsten_vx in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-12-2005, 06:30 PM
  4. bonnet washer neon light wiring issues
    By joeyandhisVT in forum Electrical Wiring / Questions
    Last Post: 26-08-2005, 07:49 PM
  5. bonnet washer neon light wiring issues
    Last Post: 16-08-2005, 06:12 PM
