Originally Posted by
goldencommodore
hi i got a vt and i want to make a better sub box i have 1 12" fusion powerplant sub, and i want to put it into a rectangle box which will measure 800 mm wide, 450mm high, and 400mm deep, im thinking about putting a port in it. ( i need to know how be to make the port to.) How do i work how many litres this box is and will it be ok and also i generally listen to rap, dance trance music, should i make it ported, i want heaps of boom bass.
thanks guys...
look on the fusion website and find the recommended sub box specs for your fusion sub. once you get them go to this website which will be able to help you a whole lot to get the maximum potential out of your sub. All you need to do is put in your dimensions in and presto.
RE Enclosure Calculator
My car audio:
CD tuner: Alpine CDA-9884E with Ipod interface
Front speakers: Alpine Type R SPR-17S 6.5 component speakers, powered by a avant-garde 23dxi 2 channel amplifier - 2x51 watt RMS
Rear speakers: pioneer coaxials connected to tuner
Subwoofer: Alpine Type R SWR-1222D 12" 2 ohm dual voice coil 500 watts RMS powered by a response precision 2x150 watts RMS 2 channel amp bridged to 500 watts RMS @ 4 ohms
