replaced an old pioneer headunit with a alpine cda-9885 and the alpine isn't working. don't know what would be causing the problem as the wires are connected correctly, it just doesn't wanna turn on.
one thing to come of this though is that now the central locking doesn't work![]()
Checked your fuses? Both for the car, and the inline one for the HU?
Best thing to do when installing a HU is to test it before you fully mount it. That way, if anything doesn't work, you can easily fix it.
yeh sounds like youve blown a fuse, should be an easy fix![]()
did u have the battery disconnected when your were doin the install?
battery was disconnected, and i did test the headunit before mounting, thats how i know it doesn't work. checked the fuse in the headunit and it was fine, will check the others
You need a multimeter to check it. You simply need the black grounded, yellow and red wires connected to 12V. Use your multimeter to confirm that there is 12V on both the red and yellow wire. Disconnect all other wires, speakers etc, as speakers that are wired incorrectly can stop the head unit working as a safety measure. If you have the HU grounded and power and it still doesnt work, and you have checked the fuse (use your multimeter again to check it) than the unit is faulty and you can send back under warranty.
assuming the deck was brand new?
was a blown fuse, replaced fuse and it works. but i now i have other problems. firstly the headunit doesn't turn on automatically, have manually turn it on everytime. secondly the headunit doesn't remember any of the settings i change and so when it next gets turned on, i have to do it all over again. damned annoying
sounds like you dont have your constant power connected, its usually the yellow wire on the back of your deck. might wanna double check its connected well, and that you are connecting it to a constant source of power.
sounds like the ACC and constant +12v need to be switched around.
Power is measured in DECIBEL
swapped the wires around and all is good. thanks guys
