Results 1 to 9 of 9
Thread: putting speakers in vt
    vt acclaim
    Jan 2008
    Angry putting speakers in vt
    how do i remove the speaker covers in my vt stupid question i know my first vt and im not sure on how to do it
    daron's Avatar
    daron is offline wizfiz
    VE SSV
    Mar 2006
    adelaide
    VT feature car, WRX STI WAGON
    Aug 2006
    as he said.
    Tweeters - Remove the top 2 plastic pieces around the front of the dash they are under there.
    Parcel shelf - need to remove the whole parcel tray to remove speakers.
    Door Speakers - Need to remove the whole door trims to get to the plastic speaker pods.
    also they are 6inch not 6 /1/2 inch pods, but can be cut down easy.
    vx s
    Sep 2008
    auckland nz
    as the door speakers are 6inch i take it some 5.5 inch splits shall fit in easy as ?? and were abouts do u guys put the splitter box?? do i have to put some silicone on it and attach it inside the door like i have had to do in other cars or do i try and put it in the door pocket and make it look trick ( just more anoying )
    fabz's Avatar
    fabz is offline I Can Do Science Me
    Blown V6 VT commodore 5 speed
    Jul 2005
    In My Car!!
    how do you remove the parcel shelf? is there a write up?
    .:Blown VT V6, DAJ37:.
    vx s
    Sep 2008
    auckland nz
    hmmmm car door in parts does the factroy stero have spliters or what as i got the same color wires at the tweeters and the door speakers?? were do these split up or do i need to run all new wires from splitter box or what ?? urgent help required or do i have to rip out whole head deck and everything and chuck in lazy one i have lying around??
    SweetWagon's Avatar
    SweetWagon is offline booosted
    VS Berlina Wagon Supercharged & VU SS Ute
    Jan 2006
    Springwood NSW
    Quote Originally Posted by holden boy View Post
    No crossover box on the factory speakers, I believe there is just a simple inline resistor on the tweeters. You don't need to remove the head-unit, But it would make it easier, and much easier to run your own wiring for the crossover,but retain the factory wiring into the door as its a pain to route new wire through the rubber door jam grommet.
    vx s
    Sep 2008
    auckland nz
    cheers for that i put new cross overs and mids and tweaters in and the factory head unit has no were enough grunt to power them lol resorted to standard ones not happy bout it but will have to go shopping and i arn't going to swap back ones over but i did get pull wire through to doors so going to make new stero install a easy task .
    danja's Avatar
    danja is offline Swerves for gay koalas
    CBF 250 and a Levin ZR
    Mind Me Bloody Beer Champion!
    Jan 2006
    Post
    Quote Originally Posted by fabz View Post
    1. Under the rear seat there are two tabs/handles, pull these outwards (towards the front of the car) while lifting the front of the rear seat. It will just pull off, put to one side.
    2. Remove two bolts from the bottom of the two window seat backs, then slide these upwards to disengage them from the chassis. Put to one side.
    3. Lower centre armrest, and remove the plastic cover from the top of the ski port (where the centre armrest lock latch receiver is). There are two plastic clips, gently pull them out.
    4. Open the flap on the parcel shelf for the child seat restraint and remove the bolt.
    5. Remove the two plastic clips from the top-rear of the parcel shelf, and the clips from the front (where the seat backs were covering, I can't remember if there are 2 or 3, but they are all obvious.
    6. The parcel shelf is now un-secured, remove by gently pulling one corner out, then slide the whole shelf out of the car.
    Install is reverse of removal.
  1. Putting Rear Parcel Shelf Speakers In Berlina
    By mickey in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-06-2009, 10:06 AM
  2. Replies: 18
    Last Post: 06-01-2008, 07:09 PM
  3. VT speakers taking out and putting in new ones?
    By Semtex in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-11-2007, 06:12 PM
  4. putting my amp in
    By Ben. in forum Car Audio
    Last Post: 15-02-2007, 09:39 PM
  5. Putting a 3.8 into a VK
    By VRSS in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 15-05-2006, 08:34 PM
