Results 1 to 9 of 9
Thread: Wiring Amp
    VR Commodore Exec
    Oct 2007
    Ballarat
    Default Wiring Amp
    Hi guys, i am new to car audio and i am wiring up my first sound system. Just have a question.
    On the side of my 4ch amp there are 4 holes im pretty sure they are called the Line-input, there are 2 white and 2 red holes and when i put a plug in one of the white and red holes to run to my head unit only my sub works and not the 2 rear speakers but when i switch the two plugs over to the other white and red hole the speakers work but not the sub. How can i get them to work all at the same time?
    roon_VR's Avatar
    roon_VR is offline VR executive Commodore
    3.8 V6 executive SII VR
    Mar 2007
    Quote Originally Posted by MG's VH Wag View Post
    Welcome to the car audio scenario
    What you'll need is an RCA splitter for the two rear speakers. A 1-into-2 RCA splitter to be precise.
    My car audio:
    CD tuner: Alpine CDA-9884E with Ipod interface
    Front speakers: Alpine Type R SPR-17S 6.5 component speakers, powered by a avant-garde 23dxi 2 channel amplifier - 2x51 watt RMS
    Rear speakers: pioneer coaxials connected to tuner
    Subwoofer: Alpine Type R SWR-1222D 12" 2 ohm dual voice coil 500 watts RMS powered by a response precision 2x150 watts RMS 2 channel amp bridged to 500 watts RMS @ 4 ohms
    VR Commodore Exec
    Oct 2007
    Ballarat
    So i need the 2 chords that come from the head unit to split into 4 so i can connect it to all 4 holes? Is that correct?
    roon_VR's Avatar
    Mar 2007
    Yeah, if you want to buy 2 RCA y-splitters, but another way that it can be done is you use one RCA plug (white or red) from the head-unit to the amp for the subwoofer (since it's only one speaker hence one RCA plug). Then you need a 1-into-2 RCA y-splitter to plug into the 2 other RCA plugs on the amp, giving you a total of 3 RCA plugs used up on the amplfier.
    My car audio:
    VR Commodore Exec
    Oct 2007
    Ballarat
    Ok thanks heaps for that. So it doesn't matter what colour plug goes into the amp for the sub? White or black.
    roon_VR's Avatar
    Mar 2007
    I dont think it does matter, but just experiment a bit and you will get it.
    My car audio:
    VR Commodore Exec
    Oct 2007
    Ballarat
    Thanks mate, just another question. I plugged my sub up just by itself and im finding it hard to get some noise out of it. When i turn it up it starts to distort and i can't get much volume and bass out of it, the speakers give out more volume and bass than it does.
    What can i do to get more volume and bass from it?
    roon_VR's Avatar
    Mar 2007
    Try turning up the gain control and see if you get anything. What kind of sub and amp do you have?
    My car audio:
    VR Commodore Exec
    Oct 2007
    Ballarat
    I have a Kenwood 12" 1000watt sub and a Avalance 600watt amp. I think it may be my amp, it was only a cheapy cause i wasn't planning on running a sub.
  1. wiring
    By 12000 in forum Electrical Wiring / Questions
    Last Post: 28-04-2007, 05:26 AM
  2. VS Ute Wiring
    By rus in forum Electrical Wiring / Questions
    Last Post: 25-12-2006, 07:07 PM
  3. Converting standard fog light wiring to driving light wiring
    By tungsten_vx in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-12-2005, 06:30 PM
  4. VC wiring.
    By SSGEN-3 in forum Electrical Wiring / Questions
    Last Post: 14-04-2005, 08:53 PM
  5. VC wiring?
    By SSGEN-3 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 24-03-2005, 09:52 AM
