I've got a commodore VZ Executive with a custom Stereo Installed in it.
PIONEER TS D161R in the Back
PIONEER TS-C160R in the front
PIONEER TS-D691R For the parcel shelf when i get em...
A JBL sub I forget its specs...
and a pair of amps...
Now everythings working fine, the biggest issue i have is the front doors dont seem to be able to handle the grunt of the front speakers, They rattle and shake and it quite frankly screws the quality.
any idea's?
yeha replaces them with better ones
make sure they screwed in tight
the yelow cone series really sound crap unless on a good amp
i kwo lots ppl think they awesome but they not that crash hot
also try sound deadner in doors
double check amp settings
replace the doors?
sound deadner should help alot
Buy some Dynamat, Best sound deadener there is. Give Marty at FHRX studios a call, He will give you a good price and will deliver Aus wide.
Had another double check of the amp and it was set to +12 Bass it was overworking the speakers and basically doofing the door to death, i've switched it back to normal and it works fine now, i'm going to look into the deadener though, does it block out road noise? thats what the descriptions of it seem to say...
set your hpf on your speaker amp to around 120hz or so, it should clean it up a lot
