OK, sorry if this has been covered but i cant find it anywhere, I need a bit of help wiring up my system... i have: head unit, speakers front 6", rear 7" by 10" mtx 4 channel amp and 10" sub..... could someone tell me how to properly wire it all up? thanks
who recommended you to get the 4 channel amp? its going to be a bit weird to wire up the sub to the 4 channel amp. unless you bridge 2 channels together and use the other 2 for the 7x10s.
i went to repco and got a wiring harness, super cheap sell to, all u need is the brand of stero and type of car, it a two peice harness plugs straight in takes 1 minute to wire up, then run rca's and power cables into the boot for amp, and just changed the spekers, did it that way cause i want to use the existing wires, its easy as, or u can run seperate cables through ur dash and doors, had no troble doing it my way, goes hard
i would get a 5 channel or get another amp 4 the sub , get another 10"
as for installation
The head unit
http://forums.justcommodores.com.au/...val-vn-vs.html
This is for the rear speakers
http://forums.justcommodores.com.au/...k-warning.html
thanks for the other tips too
If you have a 4Ch amp your best bet is to, Run your front speakers of 2 Channels and bridge the other 2 to run your sub.
ok, and just connect the 7 by 10's to the deck? how do i bridge the channels?
