Results 1 to 12 of 12
Thread: the search for good ground?
    Haydz's Avatar
    Haydz is offline 346 cu/in
    VS UTE LS1 T56
    Nov 2007
    Liverpool.Sydney,NSW
    Default the search for good ground?
    hey guys just looking to improve the quality of my ground for the two amps in my boot just wondering where other vn vp vr vs owners have grounded theyre system any help will be good thanks. and or pictures,
    Cobez's Avatar
    Cobez is offline LS-EXUAL
    2004 S2 VY SS Ute
    Feb 2007
    Sanded back a section of paint on the back of the rear seats (the steel frame) in the boot, rust proofed it, used a self tapper and grounded it there. Works fine.
    Quote Originally Posted by wikky
    As already stated, mate you're an absolute gherkin strummer.
    commsirac is offline Banned
    vx
    Aug 2007
    Quote Originally Posted by Haydz View Post
    How have you determined the quality of the ground you have at the moment?
    Do you have interference problems, or hums?
    One method is to simply test the voltage difference between the grounding point for your amps and the return ground that leads to the -ve terminal of the battery when you have the amps powering along.
    You'll need some extension wire on your multimeter, a difference of less than 0.1V would be excellent when drawing 20A or more.
    if you have interference probs it may be worth measuring the difference in voltage between the head unit earth and the amps earthing point.
    vu "s" S2 5.7
    Sep 2007
    melb s/e subs
    would anyone also know one for a vu ute??? the amp is behind the drivers seat...
    VU 'S'
    Sep 2005
    In the corner where the carpet ends at the base of the rear wall. I've had no problems.
    When the going gets weird, the weird turn pro.
    VK
    Jul 2004
    most should be able to get away with using the child restraint bolt as a good enough ground, but make sure to scratch the paint away. This is sufficient in most cases, however as you are grounding on sheet metal over the chassis it isnt perfect. I remember the ex forum sponsor aps saying once that the best place to ground was on the underside of the car, forward of the rear axle. Very costly and time consuming to achieve. Although if you really want to, kits are available to do it.
    Phreddy's Avatar
    Phreddy is offline Bye SV6 - still love you
    VS-II Statey-8
    Apr 2005
    W-Sydney NSW
    Several times I've used the "upper crossmember" (well, that's what I would call it ) - basically it's the box section where the back seat frame joins the parcel shelf metalwork, accessible from inside the boot. As bezz has pointed out though, the kiddie seat restraint bolthole would do just as well, but DEFINITELY remove the paint from the surface first. If that's not done you're only depending on the threads of the bolt / screw to make the connection, and that's just not adequate.
    Don't underestimate the problems that a dodgy ground will cause!
    Cheerz.
    New look ASR Website online now!!
    www.asr-audio.com.au
    Interior lighting and audio specialties
    for VT/VX & VY/VZ Commodore / Monaro
    NOW VE DASH LIGHTING CONVERSIONS!!
    PLUS TECH2 DIAGNOSTIC SERVICES
    JBL Car Audio dealer
    vu "s" S2 5.7
    Sep 2007
    melb s/e subs
    yeah sweet cheers fellaz, i done it in the morning jus screwed a button head screw into the floor of the car, worked a treat! thanks anyway boys
    fazz1977's Avatar
    fazz1977 is offline myspace.com/fazz_himself
    1992 VP Executive Wagon, L27 V6 3800
    Aug 2005
    Frankghanistan, Melbourne, VIC
    Yep, I floor-panned my grounds, and put in a 4ga battery ground so there's no bottlenecks. Made heaps of difference.
    Life's Grouse in Frankston South!
    roon_VR's Avatar
    roon_VR is offline VR executive Commodore
    3.8 V6 executive SII VR
    Mar 2007
    I've uploaded a couple of pictures as to where i've grounded my amps. Ever since i've used this ground point, my car has been starting better for some reason. 1st picture is what it looks like and the 2nd picture is to give you an idea where the bolt and nut is.
    Attached Thumbnails Attached Thumbnails the search for good ground?-dsc05072.jpg   the search for good ground?-dsc05073.jpg
    My car audio:
    CD tuner: Alpine CDA-9884E with Ipod interface
    Front speakers: Alpine Type R SPR-17S 6.5 component speakers, powered by a avant-garde 23dxi 2 channel amplifier - 2x51 watt RMS
    Rear speakers: pioneer coaxials connected to tuner
    Subwoofer: Alpine Type R SWR-1222D 12" 2 ohm dual voice coil 500 watts RMS powered by a response precision 2x150 watts RMS 2 channel amp bridged to 500 watts RMS @ 4 ohms
    daron's Avatar
    daron is offline wizfiz
    VE SSV
    Mar 2006
    adelaide
    roon_VR's Avatar
    Mar 2007
    Quote Originally Posted by daron View Post
    captain dodge there
    well done hehehe
    get a terminal
    haha yeah i haven't got around to actually crimp them into a terminal. Seems to do the job.
    My car audio:
  1. Best Spot to Put Ground
    By tfacter in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-02-2008, 06:33 PM
  2. Ground Point
    By calais_cruzin in forum Car Audio
    Last Post: 14-02-2007, 03:59 PM
  3. Door ground!
    By HoZy in forum Electrical Wiring / Questions
    Last Post: 18-04-2006, 07:56 PM
  4. Ground Control
    By soyaman in forum Jokes/Humour
    Last Post: 25-02-2006, 10:52 PM
  5. Ground Wire in VR/VS?
    By SMIT in forum Car Audio
    Last Post: 17-01-2006, 11:21 PM
