Results 1 to 8 of 8
Thread: remote wire on headunit an other stuff???
    vs equipe
    Mar 2008
    Default remote wire on headunit an other stuff???
    ok well on my vs, previously i installed a new pioneer headunit, 280 watt 6' kenwoods in the front and, 350 watt 6x9' pioneers in the back its all fine. Now i bought a sub and an amp an im just having a few problems with putting it together. Firstly i have no idea which wire is the remote wire out the back of the headunit???? to get the amps power cable through the firewall whats the best way to do it??? and... shoving the wires from the back of the headunitt through to down in the footwells is also causeing me greif because the rca wires dont fit through the gaps!!! any help would majorly be apreciated!!!
    calais_cruzin's Avatar
    calais_cruzin is offline Calais_Rattling....
    92 VP Calais 3.8
    May 2006
    Gold Coast
    With the cable thru the firewall, u should have a rubber gromet to the left side of brake booster for the clutch for manuals, put it thru there if u have a auto as most are.
    With the remote wire, check ur wireing diagram manual u got with the h/u but most have the wire marked with a tag to show what one it is.
    Run ur rca's on the opp side to the amp power cable.
    U can just drill a hole in the firewall, but its defectecable in sum ppl eyes
    ________________________________________
    vs equipe
    Mar 2008
    ok thanks for that!!! coz wen i put the head unit it it buggered up the aerial so wen i got the car serviced i got them to wire the aerial to the headunit and im guessing they wired it to the remote thing, the aerial worked i just had no control of it going up and down so it just stayed down so im guessing when the sparkie sed he wired the aerial to the headunit he wired it to the remote wire on the head unit! i know which wire that is. Just one quesion about it... do i have to disconect that aerial wire now or can i just strip some back an connect the remote from the amp to it??? will both the amps remote and the aerial still work??
    92 VP Calais 3.8
    May 2006
    Gold Coast
    there should be 2 wires there, one for ariel one for amp.
    Ur ariel should only come up when u select radio, other wise its on ur amp wire if i comes up when ever h/u is on
    vs equipe
    Mar 2008
    yeh its definatly connected to the remote, so will it cause problems if the headunit remote wire is conected to two things at once? like if u just strip a bit off that wire an connect the amp wire to it??
    SweetWagon's Avatar
    SweetWagon is online now booosted
    VS Berlina Wagon Supercharged & VU SS Ute
    Jan 2006
    Springwood NSW
    Quote Originally Posted by calais_cruzin View Post
    Your forgetting Pioneer heanunits only have one remote wire, not separate radio and amp/accessory's wires.
    Quote Originally Posted by hayesanator View Post
    Yes that will be fine. They dont draw much current, only used to trigger stuff, That is what i have done with my amp and antenna. It should be the blue wire.
    Power is measured in DECIBEL
    daron's Avatar
    daron is offline wizfiz
    VE SSV
    Mar 2006
    adelaide
    im with nv6pwr it will be fine to run antena and amps off this blue/white wire
    and yes pioneers only have 1 remote/ant wire shared
    vs equipe
    Mar 2008
    ok well ive pretty much finished everything just one problem to do with the firewall, i had a poke around next to the brake and have no idea wat this rubber gromet thing is i cant see anyway to poke the cable through an im not sure if im suposed to take the stuff above the brake apart???
  1. VY remote on wire for amp
    By c0mmodore in forum Car Audio
    Last Post: 05-02-2008, 08:10 PM
  2. can i run a remote wire of another remote wire
    By Burnout_bro in forum Car Audio
    Last Post: 07-05-2007, 11:16 AM
  3. Remote wire
    By [NatHAn] in forum Car Audio
    Last Post: 15-04-2007, 02:46 PM
  4. remote wire on pionner DEH-P1Y
    By beefcream in forum Car Audio
    Last Post: 28-04-2006, 01:41 PM
  5. Amp remote wire
    By yogi_6_9 in forum Car Audio
    Last Post: 19-01-2006, 01:41 AM
