"Need help installing head unit into VS"
i know what i'm doing in terms of the wiring etc,
however i have one problem that with all the RCA cables connected into the back of the head unit i can not get the unit to fit back in...
does anyone have some advice?????????
You will need to use right angled RCA plugs to get it to fit in. The normal type sit out too far and hit.
even right angle is a bitch to fit in if there is 6 of them.
how much do you like your heater? just remove the heater core, then heaps of room.
otherwise, you will just need to wiggle and maybe have the unit sit out a tiny bit. the stock one is pretty far back as well.
you could always put it in the spare pocket under where Headunit goes and put a TV in. Just a thought, Nah its not easy whatever you do but u have to use the right angled RCA's
im using right angle rca's and still cant get it in right???
Power is measured in DECIBEL
Thats correct about heating up the heater box. I have done it to 3 different Vs's and works very well. We used straight Rca cables and there was no problem with fitting, taking in mind we did mount the head unit a little further forward.
Looks the part and nothing has been affected, eg heater or RCAs.
Thanks
