Results 1 to 19 of 19
Thread: cap
    94 vr ss
    Oct 2007
    Default cap
    ok i did do a search about but it dint cum up with my problem ok i have the au thermo fans 2 12 inch subs and a 1000 watt d class mono block amp after about 30 mins of driving the subs will cut in and out until i turn it down now iv bean told get a new bigger battery and i bean told to get a bigger altornator and then i rang auto barn today and thay sed a cap shod fix it so what do use think
    Jan 2008
    Capacitors are the biggest waste of money.
    A bigger battery would be a much better option. But wouldn't necessarily fix your problem.
    Can you please give me the brand and model of your sub and amp.
    Is it all cheap equipment? (nothing wrong with that)
    What kind of car?
    Then we can get into it!
    94 vr ss
    Oct 2007
    nah good stuff i have a vr ss its a keenwood amp not shore on part number can get it later if need be and there 12 inch clarion subs 500 watt etch sub
    VRII Acclaim
    Jul 2005
    The problem may not have anything to do with the voltage (and therefore battery/alternator/cap) but the amplifier itself. If the amp is getting too hot, because it is being worked harder than it has been designed for, it may be going into protection mode. Are your lights dimming or anything like that? If yes, look at things like battery. If no, suspect the amp. I wouldnt be calling that autobarn again - they dont know what theyre talking about and are just trying to sell you $hit.
    VS Acclaim
    Jun 2006
    while caps do sometimes have a place, with that gear you shouldnt need any mods to the electrics or even a new battery... id be looking at my wiring first mate - how are you earths? or as Kopper says it may be the amp - is the load appropriate?
    "The crisis of today is the joke of tomorrow" HG Wells
    94 vr ss
    Oct 2007
    i was saying that to the guy today it cum in the car the wiring kits not up to my standards its pretty **** wires i was nerly going to spend like 500 on a bigger altornator so u recon a bigger battery wat have u got in ur car
    94 vr ss
    Oct 2007
    VS Acclaim
    Jun 2006
    you got VD brother
    The dimming of your lights indicates a voltage drop over your electrical system. what gauge wire you running mate? and where is your amps earthed? ps what state are you in i have some cable that may be of use i personally recommend fixing the wiring otherwise even with a new battery you'll still have probs. wiring fix should be enough
    94 vr ss
    Oct 2007
    im in sa yeh im going to get the top of line from auto barn and my amp is on my flip part of my back seat i dont no wat gauge wire it is i no i use to have bigger in my old cars it is earthed just above it on the parcel shelf
    VK
    Jul 2004
    other guys are right, dodgy wiring and earth. At the very least check that the paint has been removed where the earth wire makes contact to the car.
    94 vr ss
    Oct 2007
    VK
    Jul 2004
    daron's Avatar
    daron is offline wizfiz
    VE SSV
    Mar 2006
    adelaide
    if you have a good battery and propper size power/earth cable you dont need a cap
    caps waste time i run 3 amps and never had a prob
    94 vr ss
    Oct 2007
    Phreddy's Avatar
    Phreddy is offline Bye SV6 - still love you
    VS-II Statey-8
    Apr 2005
    W-Sydney NSW
    Joe, bezz, daron - they all said it - get the wiring sorted out, good solid ground point, inspect the battery terminals - maybe replace them if they're a bit shoddy.
    THEN see if you're still getting dimming light problems and such - if so, then you might need a reco'd alternator. Really even the stock alternator should be OK - I don't really know, but I would think it would have to be 80A or more - my car has a 100A alternator as standard. At any rate, once you get all your connections sorted out (which are what costs a LOT in voltage drop terms), your alternator should be able to cope with that fairly easily.
    A capacitor is definitely not going to help you at all - unless the salesman can convince you that your wallet is too heavy. They do have their place, but certainly not here.
    New look ASR Website online now!!
    www.asr-audio.com.au
    Interior lighting and audio specialties
    for VT/VX & VY/VZ Commodore / Monaro
    NOW VE DASH LIGHTING CONVERSIONS!!
    PLUS TECH2 DIAGNOSTIC SERVICES
    JBL Car Audio dealer
  16. #16
    VZ Exec Wagon
    Jun 2005
    Perth, WA
    where do i look for an uprated alternator?
    VZ Wagon (dual fuel)
    Lowered on lovells springs
    VE SSV rims
    2 1/2 stainless exhaust with DD exit
  17. #17
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    If your amp is cutting out after playing for a while, it's MOST likely to be a heat issue. If it's cutting out as soon as you start playing music, it's most likely a wiring issue.
    It sounds like you need to look at both because your amp is cutting out after a while and you're also getting dimming.
    Don't even consider a capacitor, battery or alternator until your wiring is up to scratch.
  18. #18
    94 vr ss
    Oct 2007
    ok tnxs alot guys and neobristol u can get it from any car part shop realy
  19. #19
    VRII Acclaim
    Jul 2005
    Quote Originally Posted by thekid View Post
    yeh ok so u all say that a cap is realy just for looks then
    Not always, but for a lot of people that is really all it is (if they know it or not).
