Hey ppl I was just wondering if anyone knows if it would be possible to put a single din headunit in a VE Clubby (Or any VE for that matter) I was thinking since you can't take out the factory headunit I would like to see if I can put it down the bottom where my little compartment thing is under the aircon controlls... That way I can have my high quallity audio with all my MTX speakers and amps..
You have a VE... the current headunit cant be pulled out of that thing unless you like to hear only the noise of the starta motor when you turn it on... they dont start if you pull the headunit out... you could put it in the tissue tray under the headunit (if they have one... i think they do)... but other than that...YOU
have fun....
I've heard something about a box which hooks up to the back of ur headunit. Its a small box which turns the DC current of the headunit into RC. Should look into it. I think it was about $300.00 which allowed you to hook up amps and subs etc.
ya can add amps and sprks wihtout a 300$ box
ya can get line lever converters that ya can use
about 30 bux from most car audio shops
i would not be getting the line level converters. i would be waiting or speaking to phreddy at asr audio and see if he can work out anything as he has for the vt-vx
Apparently the VE head units or hooked upto the A/C unit and central wiring system. Bit shi..y a.
yeah the ve is intergraded
fhreedy does a good kit hes a smart little man good work
but
i know a person has had his kit and it was good worked heaps well but there is nothing rong with line level converters if done right and you really cant tell the diference much
they now run line level converters and say its basicly the same sound just missing the inputs for ipod
