Results 1 to 9 of 9
Thread: Best Ground for VT/VX Boot
    1991_Vn2nV's Avatar
    91 VN Berlina & 03 VY Berlina
    Mar 2006
    Gumeracha, Adelaide Hills
    Question Best Ground for VT/VX Boot
    Did a search but it was mostly VN/VP/VR/VS stuff.
    I was trying to figure out why a friends sub was not working today, and I found the ground was fair dodgy despite being professionally installed.
    At present the ground is run to the bolt behind the middle fold down section of the back seat up the top.
    The amp is a Pioneer GM-7300M running at 2ohm (360rms) and the sub is a TS-W307D4 which is a DVC 12" sub rated at 400wrms.
    1.) So, where is the best place for a ground for a VT boot?
    2.) What is the ideal size for power and ground wires? I thought 4 gauge, but its only got 8 gauge wire for power and ground.
    | evaN |'s Avatar
    | evaN | is offline mmm bass
    VT
    May 2006
    SE Melbourne
    Quote Originally Posted by 1991_Vn2nV View Post
    it all depends on how much current he's running and if he is planning on upgrading in the future.
    American Wire Gauge, AWG Cable Size Description for Copper Wire Cable
    heres a table with how much each size wire can handle roughly. Don't know how accurate that table is though
    But according to that table, 8 gauge can only handle 23.6amps.
    so the maximum that wire can handle is 14.4volts x 23.6 amps = 339.84watts
    so 4 gauge would of been a better for him.
    how professional are we talking abuot here lol
    Mar 2008
    ground is anywhere decent you can find
    according to GM-7300M Car Amplifier - - Pioneer Product Archive that amp draws max of 33 amps , so yes 4 guage should have been fitted , go back to the 'professional' that installed it
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    I've had 2800Wrms worth of amps in my car and I used the bolt under the rear seat that hold the back rest in place. I sanded the metal bare and bolted they ring terminal under the rear seat metal loop.
    1991_Vn2nV's Avatar
    Mar 2006
    Quote Originally Posted by | evaN | View Post
    Yeah, I won't name the place that did it but it wasnt very good. What they've done looks good, but thats about as far as it goes Its a girls car, so maybe they figured they would get away with it.
    She is looking at purchasing a second sub, so I might take a look before I fix it and fit perhaps 2 guage if the amp she chooses warrants it.
    Quote Originally Posted by johnnie5 View Post
    Ah excellent, cheers mate (I shoulda looked on the Pioneer site myself, all I knew was it had 2 30 amp fuses so I was assuming it would draw atleast 30amp).
    Quote Originally Posted by StoneX View Post
    Which bolt exactly is that? The one at the centre top behind the rear seat? Or at the bottom?
    Where it is now.. Is where the button is to let the middle section fold forwards, its behind there (on the back of the metal clip that the top of the folding section clips onto).
    1991_Vn2nV's Avatar
    Mar 2006
    Also, with that amp: "Max. current consumption (A/4Ω) 33 A"
    So the rating would be different for 2ohm?
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    I have mine at the bottom underneath the rear seat (the base bit, not the back rest). The bolt goes through the loop that holds the back rest in place. The metal isn't 100% flat, but the contact seems to be fine for 140A+ that my engine bay fuse holder was showing.
    wrx884's Avatar
    wrx884 is offline WA's ASR Rep
    VT Commodore Exec/5L VP Calais
    Mar 2006
    Heres where i put my grounds 1 on each side its behind the back seat in the boot almost near the bottom floor seems a good place as any. Im only running 8 gauge tho my gears prolly not puttin out near the power u r gettin.
    Check out my ride in progress.... 98 VT V6, V8 Supercar kitted
    Daily toy.... 92 VP Calais 5L
    Chirpstr's Avatar
    Chirpstr is offline A new project attack
    VR Berlina M5, VP M5
    Sep 2007
    Yeah mate where the back seat bolts into the body just put it there. Best spot I could find.
  1. Diff on Ground
    By AdamAnt in forum VY Holden Commodore (2002 - 2004)
    Last Post: 08-03-2008, 12:39 PM
  2. Best Spot to Put Ground
    By tfacter in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-02-2008, 06:33 PM
  3. Ground Point
    By calais_cruzin in forum Car Audio
    Last Post: 14-02-2007, 03:59 PM
  4. Door ground!
    By HoZy in forum Electrical Wiring / Questions
    Last Post: 18-04-2006, 07:56 PM
  5. Ground Control
    By soyaman in forum Jokes/Humour
    Last Post: 25-02-2006, 10:52 PM
