| Car Audio Anything relating to Car Audio is to be placed in here. |
06-05-2008, 11:06 AM
Ride: VR commodore v6 3.8
how do I secure sub in the boot
Hey,
I recently hooked up my 12" sony (crap i know but free) sub and a bridged 2 channel amp. The sub is in the boot in a large ported enclosure with the amp mounted on top, the problem is, i don't know how I'm meant to secure the box down without damaging the fuel tank underneath? I really need to do something cause that heavy fu**er in the back sliding around doesn't seem safe lol. So how has every1 else secured their sub? Cheers guys.
06-05-2008, 11:11 AM
Projecting
Ride: VL PROJECT
Have you considered a heap of velcro? Not ideal I know but it's a temporary solution.
Apart from that you could always put some brackets on the box and then strap it to the side of the boot.
That's if you don't want to drill.
06-05-2008, 12:08 PM
Ride: 1990 vn , 1993 vr bt1
haha i use to use stolen milk crates and bits of wood to jam it in.
06-05-2008, 12:27 PM
Ride: New VQ getting colour, YZ250F 04' & Vr Daily.
Heavy duty velcro is fine, i have 2 large strips (probably 80cm x 10cm) holding a box with 2 type R's in it which doesn't exactly make for the lightest box and i have never had a problem with movement...ever. When i smashed my old car it almost rolled...when i checked the boot the box hadn't moved at all!!!
Also, lots of car audio places use it as it's simple, cheap and effective.
06-05-2008, 01:46 PM
thanks, i never thought velcro would hold it but if it holds 2, itll hold mine. where would i get decent velcro? im assuming velcro dots from big w wont cut it lol. cheers for the replys
06-05-2008, 01:58 PM
Ride: VT Berlina
Most hardware stores sell velcro by the meter off a roll.
06-05-2008, 06:11 PM
omg thats the funky sh1t
Ride: VSII Exec, VL Exec
isnt it illegal to not have them secured to the floor? my sub and box arent secured but weighs about 40kgs....never moved once
08-05-2008, 01:39 AM
SuPaFlY -LiV3 Surviv3 Di3
Ride: VX CoMmOdOrE S2
Same, i have 2 x sony in box, weighs a s..t load, never moves, never strapped or anything to boot.
08-05-2008, 09:13 AM
Carbon Neutral -> DO IT!
Ride: VP 5-SPD / 24-SPD Racer Hybrid
Defectable item, must be secured!
Properly?
Take sub out of box, drill hole in bottom, drill hole in boot floor, bolt box to floor using bolt and washers then put sub back in. It aint going anywhere!
Velco is a cheaper option! Not as effective.
aZk.
08-05-2008, 09:47 AM
Irony is a cool word
Ride: Series 2 VX Executive wagon
In my old sedan I used bungee cords to strap it against the driver's side back corner. I used some foam to keep it the distance away so the sub could actually move.
In my wagon, I have some MDF lining the entire boot floor (for sliding drums in and out easily) and have a cut-out for the sub, with the amp bolted on brackets quite neatly behind the sub  I was very proud of myself when I did it  .
08-05-2008, 10:41 AM
Ride: VT V8 Calais
Quote:
Properly?
aZk.
Does that mean I have to secure anything I have in the boot(esky, tools ect). This seams rather stupid to me. How is the sub gunna come through the seat into the cabin in an accident? Velcro may be cheaper but it still is not going to hold the sub in a crash.
50LTRv8
08-05-2008, 11:21 AM
Dont ask me, i didnt make the rules up!
All i know is you can be done for having unsecured heavy loads. So yes, it would include eskys etc.
Dont ask me how its a hazard in the boot but appharently it is and i was just pointing out the issue.
...youd be surprised what velcro can hold up. The idea is, if you try and slide velco together(then apart) you physically cant, however if you pull the strips apart by tearing them away then you can quite easily.
Depends on how much and the size of the velcro... im confident it can hold alot of weight in a forward moving motion.
aZk.
11-05-2008, 02:48 PM
Quote:
50LTRv8
Please refer to my first post, if you saw the photos of my car that were on here after the accident you would have a different view on that  . The velcro that is used is called 'rock strap', it's an industrial grade/strength.
11-05-2008, 03:47 PM
BRING BACK HOZY!!!
Ride: Foam tuned VS Senator
If you dropped your fuel tank, i suppose you could bolt it down to the boot floor using L shaped brackets from Bunnings and some decent thickness bolts. Making sure of course nothing is sticking out underneath preventing the fuel tank from being bolted back up correctly.
But yeah, you would have to wait until there is **** all fuel in your tank, then drop the tank.
11-05-2008, 04:13 PM
